Solving Electromagnetics Problems: Tips and Hints
  • Thread starter Thread starter Wxpunk
    Electromagnetics
The discussion revolves around solving problems in Electromagnetics, specifically involving the magnetic fields generated by infinitely long wires and their effects on a rectangular loop placed nearby. The original poster expresses frustration with their approach to these problems and seeks guidance on how to tackle them effectively.
  • Participants encourage the original poster to share their attempts at solving the problems to facilitate guidance. They suggest starting with the magnetic field from a single wire and considering superposition for multiple wires. There is a focus on understanding the magnetic field's direction and magnitude, as well as the calculation of magnetic flux through the loop.
Participants have provided hints regarding the magnetic field equations and suggested breaking down the problem into manageable parts. There is an ongoing exploration of the first problem, with some participants offering specific formulas and approaches for calculating magnetic flux.
The original poster has indicated a lack of confidence in their problem-solving abilities and is looking for a supportive environment to clarify their understanding. They have not yet provided a complete attempt at the problems, which may limit the depth of the discussion.
Wxpunk
Hello! I'm looking for some hints or tips on a few problems in Electromagnetics. Everytime I approach a problem, I get frustrated and end up turning in crap. Then I find out the problems weren't so hard had I approached them differently. Anyhow, can anyone here help with this level of physics?
Oh, please don't be insulted by my asking if anyone can help from this forum. Maybe I should ask if anyone will help. :smile: If you guys are willing to help, I'll post a few problems.
Thanks!
Wxpunk
Why don't you post a question & YOUR attempt at solving it, & maybe someone can show you the light.
Yes we will help if you post your Que along with Try, but we want to see your attempt first even your thought process will help us to show u way
Okay, here's the problem:
Two infinitely long wires carrying currents [tex]I_1[/tex] and [tex]I_2[/tex]
cross (without electrical contact) at the origin. A small rectangular loop is
placed next to the wires, as shown below
http://home.insightbb.com/~wxpunk/phys2.jpg
1. Obtain expressions for the B field at an arbitrary point inside the
rectangular loop due to the two infinite wires. Hence write down an
expression for the net B field at an arbitrary point inside the
rectangle.
2. Obtain the magnetic flux ([tex]/Phi _B[/tex]) through the small rectangular
loop (in terms of [tex]I_1[/tex], [tex]I_2[/tex], a, d, and b).
3. If [tex]I_1 = I_0 cos /omega {t}[/tex] and [tex]I_2 = sin /omega t[/tex] determine the magnitude of the induced emf in the
rectangular loop.
4. On the same graph, sketch the time dependence of the induced emf,
[tex]I_1[/tex] and [tex]I_2[/tex].
5. Suppose [tex]I_1[/tex] and [tex]I_2[/tex] are constant, but the rectangular
loop is moved away from the infinite wires at a constant velocity, v.
Obtain an expression for the induced emf as a function of the angle of the
constant velocity with respect to the x axis.
6. What direction should the loop be moved in order to produce the maximum
induced emf in the loop?
I'm still working on the first part. Like I said, I get frustrated and don't
know where to begin. This is the direction I'm going though...
http://home.insightbb.com/~wxpunk/phys1.jpg
Please help, I'm lost! :frown:
Wxpunk
The magnetic field from an infinite wire circles the wire (with a direction given by the right hand rule) and has a magnitude that is inversely proportional to the distance from the wire:
[tex] B = \frac{\mu_0 I}{2\pi s}[/tex]
You have two infinite wires; why don't you try superposing their solutions first.
[tex]B = \frac{\mu_0 I}{2\pi s}[/tex]
I hope you have done the First problem with the above formulae
For the second part calculate the flux due to I1&I2 Due to I1 it will be into the plane and due to I2 it will be outwards.
You can consider the loop to be divided into small parts then aply the formula for flux
[tex] \phi_1= \int_d^{a+d} \frac{\mu_0{I_1}}{2\pi x}dx[/tex]
If you have grasped it then we will move to next portion
  • · Replies 17 ·
  • · Replies 26 ·
