3-D coordinate systems problem
The discussion focuses on determining whether given points in 3-D coordinate systems lie on a straight line. The points A(5,1,3), B(7,9,-1), C(1,-15,11) and K(0,3,-4), L(1,2,-2), M(3,0,1) are analyzed. The key method for solving this problem involves checking if the vectors separating each pair of points are scalar multiples of each other, which confirms collinearity. Graphing is not necessary for this analysis, as calculating the slopes between the points suffices.
  • Understanding of 3-D coordinate systems
  • Knowledge of vector mathematics
  • Familiarity with the concept of slopes in multiple dimensions
  • Basic skills in linear algebra
  • Learn about vector collinearity in 3-D space
  • Study the properties of scalar multiples in vector analysis
  • Explore the use of parametric equations for lines in 3-D
  • Investigate the application of linear transformations in geometry
Students in calculus or linear algebra, educators teaching 3-D geometry, and anyone interested in understanding vector relationships in three-dimensional space.
bochai
Pleas help me with this exercises(this is not a homework):
Determine whether the points lie on a straight line.
a) A(5,1,3), B(7,9,-1), C(1,-15,11)
b) K(0,3,-4) L(1,2,-2), M(3,0,1)
Should I draw the graph, then find the slopes?
Or is there any other way to approach?
Pleas help!
By the way, I got straight A's for Calc I,II. and every body keep telling me that Calc III is easier compare to Calc II. but, I feel it's so hard, and I don't know what to do. can some one give me some advice?thanks.
If they're on a line, the vectors seperating each pair of points are scalar multiples of each other.
The simplest way is to do just what you said: Find the slope of the line through A and B and the slope of the line through B and C. They are the same line if and only if they have the same slope. Same for the second problem. Since the problem doesn't require you to graph them, that's not necessary.
  • · Replies 26 ·
