Does Subtracting a Constant from a Hamiltonian's Diagonal Change Its System?
Subtracting a constant from the diagonal of a Hamiltonian does not change the physical system it describes, as the eigenvectors remain the same while the eigenvalues shift by the constant. In a two-state system represented by the Hamiltonian matrix, the differences between eigenvalues remain unchanged despite the addition or subtraction of a constant. This principle is confirmed through the example of defining a new Hamiltonian H1 as H0 plus a constant matrix, demonstrating that the eigenvalues of H1 are simply the eigenvalues of H0 adjusted by the constant.
  • Understanding of Hamiltonian mechanics
  • Familiarity with eigenvalues and eigenvectors
  • Basic knowledge of matrix diagonalization
  • Concept of two-state quantum systems
  • Study the properties of Hamiltonians in quantum mechanics
  • Learn about matrix diagonalization techniques
  • Explore the implications of eigenvalue shifts in quantum systems
  • Investigate the role of constants in quantum mechanical operators
Quantum physicists, students of quantum mechanics, and researchers interested in Hamiltonian systems and their properties.
fargoth
correct me if I am wrong..
as i see it, i can subtract any constant from the diagonal of the hamiltonian without really changing the system it describes... am i right?
if i got a two state system, the hamiltonian can look like this:
[tex]\left( <br /> \begin{array}{cc}<br /> 0 & P_{2->1} \\<br /> P_{1->2} & \Delta E \\<br /> \end{array} <br /> \right)[/tex]
where [tex]\Delta E=H_{22}-H_{11}[/tex]
if I am right so far... then here's my problem - when you diagonize the matrix it doesn't have the same eigenvalues (i mean not even the same delta...) if you add or subtract from the diagonal... and that can't be right... so what's wrong in my view of things?
[tex]\left( <br /> \begin{array}{cc}<br /> 0 & P_{1->2} \\<br /> P_{2->1} & \Delta E \\<br /> \end{array} <br /> \right)[/tex]
You must be making a mistake.
Imagine H0 the original hamiltonian (the one you quote, for instance), and |e1> an eigenvector.
Then we have H0 |e1> = E1 |e1>
Now consider that we add C 1 to H0 (unit matrix times constant C).
Then of course C 1|e1> = C |e1>
Define H1 = H0 + C 1
H1 |e1> = H0 |e1> + C 1 |e1> = E1 |e1> + C |e1> = (E1 + C) |e1>
So we see that |e1> is again an eigenvector of H1, but this time with eigenvalue E1 + C. All eigenvalues of H1 will be the eigenvalues of H0 plus C, and the eigenvectors will be the same. The differences between the eigenvalues will of course remain the same (C will be eliminated).
cheers,
Patrick.
yeah, i found my mistake... the delta remains the same... :blushing:
