| Thread Closed |
Help Deriving the equation Ek=1/2mv^2 |
Share Thread | Thread Tools |
| Jan12-06, 05:27 PM | #1 |
Ok these are the equations im allowed to use.
Ep=mg(delta)h w=fd v_av=(delta)d/(delta)t (delta)d=v1(delta)t^2 + 1/2a(delta)t^2 V2=V1^2 + 2a(delta)d w=work done(j) f=force(newtons) d=distance(m) v_av=average velocity t=time(secs) v2=final velocity v1=initial velocity a=acceleration Ok, i havent done anything so far, because I dont know where to start. Im not asking anyone to solve this for me, i'm just asking for some helpful clues thanks |
| Jan12-06, 05:46 PM | #2 |
You could use energy conservation with the potential energy and use kinimatics to find the final speed after a change in height, using that you should get the same answer that you would have gotten with KE so you would be able to derive it. (I hope that was clear)
But thats probably cheating, are you alowed to use cal ? If so than just sum up all of the work done over an interval. |
| Jan12-06, 06:10 PM | #3 |
Ok, first question, where does the Ek come from. It is not in any other equation, doesnt it have to be in order for me to derive i?
| Jan12-06, 06:30 PM | #4 |
anyone know?
| Jan12-06, 06:37 PM | #5 |
Using Newton's Law's you can derive the conservation of mechanical energy. In essence you can derive the expression, 1/2mv^2 + mgh = 0. You then define 1/2mv^2 as kinetic energy. Is this what your trying to do?
| Jan12-06, 07:08 PM | #6 |
| Jan12-06, 07:59 PM | #7 |
Please Help
| Jan12-06, 08:16 PM | #8 |
Recognitions:
Using Calculus:
Write down Newton #2 (show a time derivitive) Most situations have Force functions that depend on location (x) rather than time. So multiply Newton#2 by dx, which can switch places with the dv. Now find the antiderivitive of each side. Without Calculus: v^2 = v^2 + 2ax ... multiply by mass, then replace Fx by Work |
| Jan12-06, 11:32 PM | #9 |
Ek arises as an interesting quantity from the "Work-[Kinetic]Energy Theorem". Start with Newton-II for the case of a constant net force F_net doing work over a displacement d. Use your kinematic equations for constant acceleration to reveal this interesting quantity.
Before you start, you should really check the correctness of the equations that you were allowed to use... although the errors that appear may just be typos. |
| Jan13-06, 01:41 AM | #10 |
I was thinking of using the fifth equation (V^2 = ...) and the first one. Look what happens if you divide the fifth equation by 2 and see how the final speed is related to initial hight. Multiplying by m should easily let you get to mV^2 / 2
| Thread Closed |
| Thread Tools | |
Similar Threads for: Help Deriving the equation Ek=1/2mv^2
| Deriving the continuity equation from the Dirac equation (Relativistic Quantum) | Advanced Physics Homework | 3 | ||
| Deriving an equation | Precalculus Mathematics Homework | 2 | ||
| Deriving an equation | Introductory Physics Homework | 1 | ||
| Need help deriving an equation | Introductory Physics Homework | 3 | ||
| Deriving the equation for drag | Introductory Physics Homework | 4 | ||
