Forces on Negative Charge in 4-Charge Square System
The discussion revolves around a problem involving four point charges arranged at the corners of a square, with three positive and one negative charge. Participants are tasked with determining the force experienced by the negative charge due to the others, using Coulomb's Law.
  • Mixed
  • Participants discuss the use of free body diagrams and Coulomb's Law to calculate forces. There is exploration of the components of forces due to the arrangement of charges and the distances involved. Some participants question the necessity of certain multipliers in their calculations.
There is ongoing exploration of the calculations, with some participants providing numerical results for forces while others express confusion about the correct approach to combine these forces. Guidance is offered regarding the treatment of components and the use of the Coulomb constant.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is a noted discrepancy in the calculations that some participants are attempting to resolve.
Punchlinegirl
Four point charges, each of magnitude 5.5[tex]\mu[/tex]C, are placed at the corners of a square 76.5 cm on a side. The value of Coulomb's constant is 8.9875 x 10^9 Nm^2/C^2. If three of the charges are positive and one is negative, find the magnitude of the force experienced by the negative charge. Answer in units of N.
First I drew a free body diagram and found that the negative charge would be attracted to all of the other charges. So then I used Coulomb's Law.
F_14= [tex]1/4\pi\epsilon_o * (5.5 x 10^-6 *5.5 x 10^-6)/ .765^2.[/tex] I know that E_o = 8.85 x 10^-12, by setting 8.9875 x 10^9= [tex]1/4\pi \epsilon_o.[/tex]
Solving this gave me 4.58 x 10^-22.
This would be the force for 2 of the charges, since all of the charges and distances are equal, except one force is in the x-direction, and the other is in the y-direction.
Next I solved for the other force, which would be the diagonal from the negative charge. I found the distance between the two charges to be 1.08 m by using the pythagorean theorem.
I split it up into x and y components and used Coulomb's Law.
In the x-direction:
F= [tex]1/4\pi \epsilon_0 * (5.5 x 10^-6 * 5.5 x 10^-6) / 1.08^2 * (.765/1.08).[/tex] and I got 1.83 x 10^-11.
Since it is a square, I got the y-direction to be the exact same thing.
Then I added together the components for both parts to get 1.83 x 10^-11 in both directions. Then I did the [tex]\sqrt (1.83 x 10^-11)^2 +(1.83 x 10^-11)^2[/tex] for my final force and found it to be 2.59 x 10^-11, which isn't right. Can someone help me? thanks in advance.
This does not seem right. The distance of the diagonal is 1.08 m, but why multiply by 0.765/1.08?
Since the two + charges on the adjacent legs are equally apart and perpendicular, the net force will be along the diagonal.
I multiplied it by .765/1.08 because that is what the sin/cos is equal to. I thought I needed to have that for the x and y directions.
Do I just take that part out from each of the forces I calculated and add everything together?
I'm confused on where to go from here.
I got .465 N on my calculator, for the nearby charges.
You know that the Force by the farther charge is LESS ...
Re-key your computation!
the Coulomb constant k = 9E9 Nm^2/C^2 is easier to use than epsilon ...
Ok I got the .465 for the two nearest charges, and I got .233 for the charge that is furthest away. Do I add these together? Or do I need to break the one that's furthest into components?
Do you want the answer in (F_x , F_y) components, or magnitude?
Either split the small one into x,y (before adding to the big ones);
or add the two big ones by Pythagoras (before adding to the small one)
  • · Replies 21 ·
