Cat & Mouse Chase: Who Will Win?
  • Thread starter Thread starter iceman632
The problem involves a cat and a mouse in a square coordinate system, where the mouse moves vertically and the cat moves towards the mouse at a faster speed. The objective is to determine who will reach their goal first, with the mouse aiming to reach the top of the square and the cat trying to catch the mouse.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the problem, including the motion equations for both the cat and the mouse. There is mention of using differential equations to describe the cat's trajectory and the relationship between their speeds.
Some participants are exploring the mathematical formulation of the problem, while others express concern about the complexity of using differential equations. There is an acknowledgment that such equations are often necessary in motion-related problems.
Participants note the challenge of avoiding differential equations in this type of problem, indicating a potential constraint in finding a purely mathematical solution without them.
iceman632
Long ago, I stumbled across the following problem:
Assume we have a square with length of the of 1 located in the origin of the coordinate system. Let's have a mouse in the origin (0, 0), too. Let's have a cat in the neighbor corner (1, 0). This is at the time t = 0-.
At t=0+, both cat and mouse start moving. Mouse always moves along y-axis with constant veocity v << 1. Thus, after some finite time tm = 1 / v it will finish its journey in (0, 1). The mouse "wins" if it comes there before
Cat, however, wants to stop it in achieving this. It is moving twice as fast (2 * v) and is always moving towards the mouse. That is, vector vc of the cat's speed is always directed to the (0, ym), where ym is the current position of the mouse. If the cat catches a mouse, it, of course, "wins" the game.
Who will win?
It's not a life matter, but I would really like to find the solution to this. I tried some computer simulation and got some results, but I need some kind of mathematical-only proof. Thanks for any replies!
1. Let y(x) be the curve in the xy-plane traced out by the cat.
Hence, the cat's position vector as a function of time is (x(t),y(x(t)))
2. Set up the info you've got, and remember that we have [itex]\frac{dt}{dx}=\frac{1}{\frac{dx}{dt}}[/itex] when changing independent variables.
3. You should get a 2.order diff eq for y.
4. As a further exercise, find out how the golden ratio is related to this problem..:wink:
I will surely look into this solution. However, I really thought that I would avoid differential equations... :frown: Seems like this is impossible in real life.
Thank you very much for your reply and all the best in New 2006!
Yes, it is generally impossible to avoid differential equations in motion problems!
  • · Replies 47 ·
10K
