Basic Thermodynamics: Solving for Energy, Volume, Pressure & Temperature
The discussion revolves around a thermodynamics problem involving two systems of ideal gases that are initially separated and later allowed to reach equilibrium. The participants are exploring concepts related to energy, volume, pressure, and temperature in the context of thermodynamic equilibrium.
  • The original poster attempts to understand how to apply the principles of thermodynamics to find the energy and volume of each system at equilibrium, as well as the pressure and temperature. Some participants question the relevance of forces at equilibrium and the definitions of variables such as energy (U). Others seek clarification on the implications of changing mole numbers and volumes as the systems reach equilibrium.
Participants are actively engaging with the problem, sharing their understanding and interpretations of the equations provided. There is a mix of attempts to clarify concepts and explore the implications of the initial conditions on the final state of the systems. While some guidance has been offered regarding the equations and energy calculations, there is no explicit consensus on the approach to take.
Participants note that the systems start with different temperatures and are not in thermal equilibrium initially. There are references to specific equations of state for the gases involved, and the discussion includes considerations of the nature of the gases (monatomic vs. diatomic) and the implications for energy calculations.
KoGs
Hello everyone first time posting here.
I have a thermodynamics question that my teacher told me should be really easy. But I am having a lot of difficulty on it. Any help would be appreciated.
For question 2 by simplying plugging in the information given I am able to get the energy of each system before equilibrium without any difficulty. And we know energy is conserved, so this total energy is the same at equilibrium. I'm kind of stuck what to do at this point.
My teacher told me to think of the forces at equilibrium. Ok so F net = 0 at equilibrium. My teacher said from there we should be able to say something about pressure. I'm not too sure exactly what that is.
I know at equilibrium we can write p(1)v(1)/n(1) = p(2)v(2)/n(2). But doesn't my n(1) and n(2) values change once we reach equilibrium? Also the volume levels of each system, as well as pressure?
Oops I guess my attachment is too big. I can't use superscripts on this keyboard so I will use T(1) to denote temperature of system 1. Ok here is the question:
Two systems of ideal gases have the following equations of state:
1 / T(1) = 3RN(1) / (2 U(1)), P(1) / T(1) = R N(1) / V(1).
1 / T(2) = 5RN(2) / (2 U(2)), P(2) / T(2) = R N(2) / V(2).
Where R = 8.314J / mol K is the universal gas constant. The mole number of the first system is N(1) = 0.5 mol and that of the second system is N(2) = 0.75 mol. The two systems are initially contained in a closed cylinder, separated by a rigid adiabatic wall. The initial temperatures are T(1) = 200 K and T(2) = 300 K, and the total volume is 20 litres. Subsequently, the wall is replaced by a freely movable diathermal piston and the total system is allowed sufficient time to come to equilibrium.
a) What is the energy and volume of each system in equilibrium?
b) What is the pressure and temperature in equilibrium?
Thanks for any help.
So, wait, I want to make sure I got this right, you have two containers that are separated by a wall that (ideally) keeps the two systems completely separate, and then they come together and it wants to know the stats of the new equilibrium? Also, the equations are as follows (what is U?):
[tex]\frac{1}{T_1} = \frac{3RN_{1}}{2U_1}[/tex]
[tex]\frac{P_1}{T_1} = \frac{RN_1}{V_1}[/tex]
[tex]\frac{1}{T_2} = \frac{5RN_{2}}{2U_2}[/tex]
[tex]\frac{P_2}{T_2} = \frac{RN_2}{V_2}[/tex]
I don't think force has anything to do with it.
Yes that is what the question is. And those are the equations. U is energy.
Okay, sorry that I didn't get back to you in time, or I hope that you eventually got it. The two systems start with different temperatures and are not in thermal equilibrium. EneSo system 1 is monotomic gas, and system 2 is a diatomic gas. I'm used to E representing energy, but for you it would be that [tex]U_{1 i} =\frac{3}{2} n_1 R T_{1 i}[/tex] and [tex]U_{2 i} = \frac{5}{2} n_2 R T_{2 i}[/tex] and [tex]U_{tot} = U_1 + U_2[/tex]. You seem to have gotten to this point well (part a), though I did not double check the actual number crunch.
For part b, all we need to find the heat entering or leaving each system which can be found by subtracting the final energies from the initial energies [tex]Q_1 = E_{1 f} - E_{1 i}[/tex] for system 1. (You should have an equation that would tell you how to solve for the final energies, I don't want to give you too many steps.) I'm pretty sure this qualifies as a constant-volume scenario, during the time for equilibrium at least (which is what we are focusing on and was part of the point of finding the new volume), which means that [tex]Q = n C_V \Delta T[/tex] where n is the number of moles and C_v is (3/2)R for monotomic gases and (5/2)R for diatomic gases if I remember right (though you really only need to solve one). Then manipulate the algebra and such to solve for change in temperature, and then use the change to find the final temperature.
