Particle Position Calculation Using Tangent Velocity Vector
  • Thread starter Thread starter tandoorichicken
    Particle Position
The discussion centers on calculating the position of a particle at time t_1=2, given its path defined by the vector function \(\vec{c}(t)=(e^t, e^{-t}, \cos{t})\) and the tangent velocity vector at time t_0=1. The velocity vector is derived as \(\vec{v}(t)=(e^t, -e^{-t}, -\sin{t})\), evaluated at t_0 to yield \(\vec{v}(1)=(e, -\frac{1}{e}, -\sin{1})\). The position at t_1 is calculated using the equation \(\vec{c}(t_0)+(t_1-t_0)\vec{c}_0(t_0)\), resulting in the final position \((2e, 0, \cos{1}-\sin{1})\), confirming the calculations are accurate despite initial notation confusion.
  • Understanding of vector calculus, particularly tangent vectors
  • Familiarity with exponential and trigonometric functions
  • Knowledge of parametric equations in motion
  • Ability to compute derivatives and evaluate limits
  • Study the derivation of tangent vectors in vector calculus
  • Learn about parametric equations and their applications in physics
  • Explore the implications of velocity vectors in particle motion
  • Investigate the use of vector notation in mathematical physics
Students and professionals in physics, mathematics, and engineering who are involved in particle dynamics and vector calculus applications.
tandoorichicken
Can someone please check my work on this?
Problem: Suppose that a particle following the given path c(t) flies off on a tangent at t = t_0. Compute the position of the particle at the given time t_1.
Given: [itex]\vec{c}(t)=(e^t, e^{-t}, \cos{t}), t_0=1, t_1=2[/itex]
Here's how I did it:
The tangent to the position vector at any time is the velocity vector, so:
[tex]\vec{v}(t)=(e^t, -e^{-t}, -\sin{t})[/tex]
[tex]\vec{v}(t_0)=(e, -\frac{1}{e}, -\sin{1}) = \vec{c}_0 (t_0)[/tex]
where I define [itex]\vec{c}_0 (t)[/itex] as the position along the tangent at time t.
Then, the position at t_1 is:
[tex]\vec{c}(t_0)+\vec{c}_0 (t_0) = (2e,0, \cos{1}-\sin{1})[/tex]
Does this result make sense?
Edit: Actually, I think the proper final equation should be [itex]\vec{c}(t_0)+(t_1-t_0)\vec{c}_0 (t_0) = (2e,0, \cos{1}-\sin{1})[/itex] but in this case the answer comes out the same.
I got the same answer, but your notation (using c and c0 instead of c and v) confused me for a moment.
-Dale
Thanks, Dale. Sorry about the notation, it made more sense in my head :-p
