Thread Closed
Problem involving displacement vectors
Share Thread
Jan24-06, 02:05 AM   #1
Alright, here's the problem:
A car is driven east for a distance of 41 km, then north for 27 km, and then in a direction 28° east of north for 26 km. Determine (a) the magnitude of the car's total displacement from its starting point and (b) the angle (from east) of the car's total displacement measured from its starting direction.
I'm not getting the right answer for part a, and I figure if part a is wrong, I'm going to have the same luck with part b.
From what I can tell, this problem is asking to obtain the total displacement by adding the vector components of each vector. I get the following numbers:
Vector 1: 41sin(0 degrees) = 0, 41cos(0 degrees) = 41
Vector 2: 27sin(90 degrees) = 27, 27cos(90 degreeS) = 0
Vector 3: 26sin(28) = 12.2, 26cos(28) = 23
Net X component: 41 + 0 + 23 = 64
Net Y component: 0 + 27 + 12.2 = 39.2
Then when I take the square root of 64^2 + 39.2^2 I get a wrong answer for the magnitude. What am I doing wrong?
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Jan24-06, 04:51 AM   #2
Quote by frankfjf
I think it's this bit that's wrong, it says 28 degrees east of north (see diagram below - this is my intepretation), so using a little trig, does that not make the x-component 26sin28 and the y component 26cos28, then carry on as normal, and you should get the right answer.
| / Where the vertical line is north, and the angle A is 28 degrees.
|A /
Thread Closed
Similar discussions for: Problem involving displacement vectors
Thread Forum Replies
displacement vectors Introductory Physics Homework 4
displacement vectors Introductory Physics Homework 0
displacement w/ vectors question Precalculus Mathematics Homework 2
displacement vectors Introductory Physics Homework 2
sum of small displacement vectors. General Math 2
