Register to reply
Loudness of a sound
by Gamma
Tags: loudness, sound
Share this thread:
Gamma
#1
Jan24-06, 11:17 PM
Gamma's Avatar
P: 333
Hi,
I have a quesion on sound terminology. When we talk about loudness of sound,are the terms 'sound intensity level' and 'sound pressure level' the same? Are these two terms indicate the loudness of sound?
My tutorial asks to write the formula for measuring sound?? I know the formula for measuring the sound level or loudeness of the sound which is
dB = 10 log 10 (I/Io) = 20 log 10 (P/Po). But measureing sound?????
Thanks for any explanations...
Gamma.
Following is the question in my tutorial:
The loudness of sound is based on intensity level measured in decibels using a logarithmic scale and is relative to (a ratio of) the weakest sound the ear can hear
Write the formula for measuring sound
Phys.Org News Partner Science news on Phys.org
What lit up the universe?
Sheepdogs use just two simple rules to round up large herds of sheep
Animals first flex their muscles
FredGarvin
#2
Jan25-06, 06:48 AM
Sci Advisor
FredGarvin's Avatar
P: 5,095
Intensity and SPL are not the same thing as you have shown in your equation of intensity and SPL. Usually, SPL is what is measured and intensity is calculated from that. Not always, but usually.
Since the question specifically asks for an equation based on intensity, then the dB = 10 log 10 (I/Io) is appropriate. However, the question is a bit misleading because loudness implies a human interaction with the sound. To be thorough, there are three weighting scales that are employed to help mimic the way humans hear, the A, B and C scales. Usually when someone mentions loudness measurements, the units are referred to as dBa, dBb or dBc referring to the weighted scale used.
Gamma
#3
Jan25-06, 10:21 AM
Gamma's Avatar
P: 333
I wrote the aboove because, I is propotional to P^2 and hence
log I/Io = log P^2/Po^2 = 2 log P/Po
Don't these do equations give the same result even though they are measured or calculated differently?
By the way I am not familier with a, b, c scale. I may have to read more on that.
Thanks,
Gamma.
Register to reply
Related Discussions
Speed of sound and sound detection lag between ears Introductory Physics Homework 5
Problem on Loudness of Sound Introductory Physics Homework 0
Sound Wave Intensity/Sound Level Introductory Physics Homework 1
Sound wave loudness 2 General Physics 0
Sound wave loudness General Physics 8
