Force must be applied to the small piston to lift the engine?
The discussion centers on calculating the force required to lift an engine using a hydraulic lift with a small piston area of 0.057m² and a large piston area of 0.208m². The force needed to lift the engine, which weighs 2900N, is determined to be 794.712N. By applying Pascal's principle, it is established that the pressure change at the input piston equals that at the output piston, allowing for the calculation of the distance the smaller piston moves in relation to the engine's rise of 0.235m.
  • Understanding of Pascal's principle in hydraulics
  • Basic knowledge of pressure and force calculations
  • Familiarity with the concept of hydraulic systems
  • Ability to calculate areas and volumes in physics
  • Study the relationship between piston areas and displacement in hydraulic systems
  • Learn about the work-energy principle in the context of hydraulic lifts
  • Explore advanced applications of Pascal's principle in engineering
  • Investigate the effects of fluid dynamics on hydraulic efficiency
Mechanical engineers, physics students, and anyone involved in the design or maintenance of hydraulic systems will benefit from this discussion.
AdnamaLeigh
In a machine shop, a hydraulic lift is used to raise heavy equipment for repairs. The system has a small piston with a cross-sectional area of 0.057m^2 and a large piston with a cross-sectional area of 0.208m^2. An engine weighing 2900N rests on the large piston. What force must be applied to the small piston to lift the engine? If the engine rises 0.235m, how far does the smaller piston move?
I correctly found the force to be 794.712N. I thought that the smaller piston moves the same length as the engine rising, but I could be wrong. I don't know how to figure that out.
By applying Pascal's principle to the hydraulic jack we get that the change in pressure at the input piston is equal to the pressure change at the output piston , therefore the input force is magnified by the ratio of the areas of the pistons at the output piston. The volume of oil displaced at the input piston will be equal to the volume of oil rising at the output piston as the engine is lifted up. From this you can find the relationship between the areas of the pistons and the distances the two pistons move during the lifting process. Notice what this new relationship obtained this way tells us something about the work done during the lifting process.
  • · Replies 41 ·
10K
