Calculate Speed of Sound with Echo Measurement
  • Thread starter Thread starter 29 clicks
    Speed
The discussion revolves around calculating the speed of sound using echo measurements, a concept that involves understanding sound wave propagation and timing. The original poster expresses uncertainty about how to approach this topic.
  • Participants discuss the relationship between distance and time in the context of sound traveling to a reflector and back. Questions arise regarding the specific calculations needed to derive speed from echo measurements.
Some participants have provided insights into the principles of sound travel and timing, while others seek clarification on how to apply these concepts to actual measurements. There is an ongoing exploration of the necessary steps without a clear consensus on the method.
The original poster indicates a lack of familiarity with the topic, suggesting that additional foundational knowledge may be required. There is also mention of needing to understand how to interpret sound wave charts in relation to the problem.
29 clicks
Can someone tell me how to calculate the speed of sound through measuring echoes. This is very new to me so I do not know where to begin. Appreciate any help. Links will help as well.
If the source and the reflector are stationary then the time it takes sound to travel from the source to the reflector is the same time it takes for the sound to travel from the reflector back to the source.
I know what you mean by if the materials are in position and not moving but i just need to know how you get the speed of sound from taking two points off (the echoes) a sound wave chart and calculating the speed of sound from that.
Divide the distance traveled by the time of travel to find the speed of sound.
  • · Replies 87 ·
24K
  • · Replies 19 ·
  • · Replies 26 ·
