Double Integrals: Solve Volume Problem
  • Thread starter Thread starter Nima
    Integrals
The discussion focuses on evaluating the volume generated by the area bounded by the curves y = x^3 and y = x^(1/3) using double integrals. The correct setup for the integration involves defining the outer variable x with bounds from 0 to 1, and the inner variable y with bounds defined by the functions y = x^3 and y = x^(1/3). This approach ensures accurate calculation of the volume under the surface defined by z = x^2 * y.
  • Understanding of double integrals
  • Familiarity with the concepts of bounded areas in calculus
  • Knowledge of the functions y = x^3 and y = x^(1/3)
  • Basic skills in setting up integration limits
  • Study the process of setting up double integrals for different bounded regions
  • Learn about the application of double integrals in calculating volumes
  • Explore the concept of changing the order of integration in double integrals
  • Investigate the use of numerical methods for evaluating double integrals
Students and professionals in mathematics, particularly those studying calculus and integration techniques, as well as educators looking to enhance their understanding of double integrals and volume calculations.
Nima
Double Integrals - Please Help!
Hi, I have a question and it asks me to evaluate the volume generated by the area bounded by y = x^3 and y = x^(1/3) and the function z = x^2.y
I'm just having a few problems with setting up the ranges of my variables x and y. I drew a sketch of the area in the x-y plane but I'm not sure what my ranges should be. My guess is: 0 <= x <= 1 and 0 <= y <= [x^(1/3) - x^3].
Help appreciated.
"Hi, I have a question and it asks me to evaluate the volume generated by the area bounded by y = x^3 and y = x^(1/3) and the function z = x^2.y"
To do dbl int's always choose one of the variables to put definite boundaries on (put them on the outer-most int), then put limits on the second int in terms of the first. You know that the graphs intersect at (0,0) and (1,1), so I'd suggest using 0 and 1 as the bounds of x, then choose y = x^3 and y = x^1/3 for the bounds on y. Then, integrate!
  • · Replies 27 ·
