How does Planck's radiation law relate to the Stefan-Boltzmann law?
  • Thread starter Thread starter Eivind
    Law
The discussion revolves around the relationship between Planck's radiation law and the Stefan-Boltzmann law, specifically how to derive the latter from the former. Participants are exploring the mathematical integration of Planck's law to demonstrate the total energy flow expressed by the Stefan-Boltzmann law.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to integrate Planck's radiation law to find the total energy emitted by a black body. There are suggestions to consider the area under the radiation distribution curve and to account for the solid angle. Some participants raise questions about the complexity of the integration involved.
There is an ongoing exploration of the integration process required to connect Planck's law to the Stefan-Boltzmann law. Some participants have provided hints regarding the integration and variable substitution, while others emphasize the need for careful handling of the integral without necessarily evaluating it completely.
Participants note that the integral involved is not trivial and that understanding the proportionality to T^4 is essential, although the exact constant may require further evaluation of the integral.
Eivind
Hi,
I have been thinking at this for quite a while now and I just can`t figure it out.
1)Use Plancks radiation law to show that the total energy flow is given by Stefan-Boltzmann law, J=@T^4, where @ is a constant.
Plancks radiation law:I(v,T)=(2piv^2/c^2)(hv/e^(hv/kT)-1)
I don't know of anything to do, can anybody give me a hint?
Eivind said:
Hi,
Try integrating to find the area under the Planck Law radiation distribution curve. (It is not a trivial integration). This should give you the energy emitted by the black body (per solid angle unit). Since it is radiating equally in all directions, multiply by [itex]4\pi[/itex] to get the total energy radiated.
AM
You'll need
[tex]\int_{0}^{\infty} \frac{x^{3}}{e^{x}-1} \ dx =\Gamma (4)\zeta (4)[/tex]
Daniel.
As has been said, you have write down the integral of Planck's law over all frequencies. As also has been said, the integral is tricky. However, you don't actually have to evaluate this integral to get the answer for which your questions asks, i.e., to show proportionality to [itex]T^4[/itex]. If you need the proportionality constant, then you do need to evaluate the integral.
Hint: in the integral, get rid of the mess in argument of the exponential, i.e., make the change of variable
[tex]x = \frac{h \nu}{kT}.[/tex]
Regards,
George
10K
25K
