Calculate Electric Field & Energy in Capacitors: Physics Problems #1-3
  • Thread starter Thread starter fish
    Physics
The discussion focuses on calculating electric fields and energy in capacitors through three specific physics problems. In Problem #1, the calculated electric field at the midpoint between two charges (+3.0 µC and -7.0 µC) is determined to be 9 x 10^6 N/C, while the solutions manual incorrectly states it as 9 x 10^5 N/C. Problem #2 addresses the electric field between parallel plates, concluding that halving the distance does not change the field strength, contrary to the manual's assertion. Problem #3 calculates the energy stored in a capacitor connected to a 12-V battery, yielding 1.27 x 10^-7 J, while the manual claims it is 2.5 x 10^-7 J.
  • Understanding of Coulomb's Law and electric fields
  • Familiarity with capacitor formulas, specifically C = (ε₀A)/d
  • Knowledge of energy stored in capacitors, Uc = 1/2 CV²
  • Basic grasp of parallel plate capacitor configurations
  • Study the derivation of Coulomb's Law and its applications in electric fields
  • Learn about the implications of plate separation on electric fields in capacitors
  • Explore energy storage calculations in different capacitor configurations
  • Investigate discrepancies between manual solutions and calculated results in physics problems
Students studying electromagnetism, physics educators, and anyone involved in electrical engineering or capacitor design.
fish
problem #1
Two point charges of +3.0uC and -7.0uC are placed at x=0 and x=.20m, respectively. What is the magnitude of the electric field at the point midway between them (x=.10m)?
E3 = (kq)/r^2 = [(9x10^9 )(3x10^-6 C)]/.10m^2 = 2.7x10^6 N/C
E7 = (kq)/r^2 = [(9x10^9 )(7x10^-6 C)]/.10m^2 = 6.3x10^6 N/C
E=E3+E7 = 9x10^6 N/C
solutions manual has the answer as 9x10^5 N/C
problem #2
If the distance between two closely spaced parallel planes is halved, the electric field between them: becomes 4 times as large.
E=4/A
E=4/d^2
if d=2, E=1
if d=1, E=4
so becomes 4 times as large
solutions manual has the answer as remains the same
problem #3
A 12-V battery is connected to a parallel-plate capacitor with a plate area of 0.40 m^2 and a plate separation of 2.0 mm. How much energy is stored in the capacitor?
A=0.40 m^2
d=2.0 mm = .002 m
V= 12V
find Uc
C=(EoA)/d = (8.85x10^-12 x .40 m^2)/.002 m
C= 1.77x10^-9 F
Uc=1/2cv^2 = 1/2(1.77x10^-9 F)(12v)^2 = 1.27x10^-7 J
solutions manual has the answer as 2.5x10^-7 J
Your answers to #1 and #3 look good to me. I'm not sure what you are doing for #2, but in any case: as long as the charge remains the same, the field within the (closely spaced) plates is independent of separation.
thanks Doc, in #2 I was getting confused about the (A)area= d^2 vs the separation distance. Q remains same, E doesn't depend on separation distance between two closely spaced parallel plates.
  • · Replies 16 ·
