How Does Integration Affect Particle Acceleration Calculations?
The discussion centers on the integration process for calculating particle acceleration using known position vectors at specific times. The position vectors are given as \(\vec{r}(10) = 10\vec{i}+5\vec{j}-10\vec{k}\) and \(\vec{r}(5) = 3\vec{i}+2\vec{j}+5\vec{k}\). The velocity vector is defined as \(\vec{v}=C_1\vec{i}+C_2 t^2\vec{j}+C_3\ln{t}\vec{k}\), and the integration must include constants for each coordinate. The correct approach involves solving two equations for each coordinate to determine the constants C_1, C_2, and C_3 accurately, ensuring that the integration constants are included to avoid discrepancies in the results.
  • Understanding of vector calculus and integration techniques
  • Familiarity with particle motion equations and kinematics
  • Knowledge of logarithmic functions and their derivatives
  • Ability to solve systems of equations with multiple variables
  • Study the integration of vector functions in physics
  • Learn about solving systems of linear equations in multiple dimensions
  • Explore the implications of initial conditions in particle motion
  • Investigate the role of integration constants in physical equations
Students and professionals in physics, particularly those focusing on mechanics and particle dynamics, as well as mathematicians interested in applied calculus and integration techniques.
tandoorichicken
How do I go about this? I finished it but I think its off a bit. I think it has to do with the extra constant that comes out of integration that I didn't take into account.
Problem: The position of a particle at times t=10 sec and t=5 sec are known to be, respectively,
[tex]\vec{r}(10) = 10\vec{i}+5\vec{j}-10\vec{k}[/tex]
[tex]\vec{r} (5) = 3\vec{i}+2\vec{j}+5\vec{k}[/tex]
What is the acceleration of the particle at time t=5 sec if the velocity vector has the form
[tex]\vec{v}=C_1\vec{i}+C_2 t^2\vec{j}+C_3\ln{t}\vec{k}[/tex]
where C_1, C_2, and C_3 are constants and t is time in seconds?
What I did:
integrated v(t) to get r(t), [itex]\vec{r}(t)=C_1 t\vec{i}+\frac{1}{3}C_2 t^3\vec{j}+C_3(t\ln{t}-t)\vec{k}[/itex] then integrated once more to get a(t)= [itex]2C_2 t\vec{j} +\frac{C_3}{t}\vec{k}[/itex]
I then substituted the initial equation for r(5) into the equation for r(t) to find the constants C_1, C_2, C_3, and then using these constants, found the acceleration for t=5 to be [itex].48\vec{j}+.33\vec{k}[/itex]
The values I got for the constants were .6 for C_1, 6/125 for C_2, and 1/(ln(1)-1) for C_3.
You NEED to include a constant term for each coordinate.
x(10 sec) = 10 , not 6 as your formula suggests.
You have 2 equations for each coordinate, you can solve for 2 unknowns.
I think that's probably the problem. If you take the values you obtained for r(5) and plug them in for r(10) [or vice versa], I think you'll find it's incorrect.
As you're solving it, for each if i j and k you should have 2 equations and 2 unknowns.
Adding the integration constant to your expression, we have:
[tex]\vec{r}(t)=\left(C_1 t + k_1\right)\hat{i}+\left(\frac{1}{3}C_2 t^3 + k_2\right)\hat{j}+\left(C_3(t\ln{t}-t) + k_3\right)\hat{k}[/tex]
Now solve for each of the i,j,k components using the initial values provided. Example for the x-component:
[tex]t=10: C_1*10 + k_1 = 10[/tex]
[tex]t=5: C_1*5 + k_1 = 3[/tex]
We have 2 equations and 2 unknowns. Solve for C_1 and k_1, plug it back into the expression you got by integrating, and we'll end up with an x-component of the form at+b
  • · Replies 17 ·
  • · Replies 29 ·
