Trying To help My Daughter With A Physics ?
  • Thread starter Thread starter Forgo
    Physics
The discussion focuses on balancing a seesaw by determining the correct placement of a second child based on the seesaw's weight. It is established that when the pivot is positioned at the midpoint of a uniform seesaw, the weight of the seesaw does not create torque, allowing it to be excluded from calculations. This simplifies the problem to balancing the weights of the two children alone. The key takeaway is that the seesaw's weight is irrelevant in this specific scenario.
  • Understanding of basic physics concepts such as torque and balance.
  • Familiarity with the principles of levers and moments.
  • Knowledge of uniform mass distribution in objects.
  • Ability to apply mathematical reasoning to physical problems.
  • Study the principles of torque and how it affects balance in levers.
  • Explore the concept of moments in physics and their calculations.
  • Learn about the effects of mass distribution on equilibrium.
  • Practice solving problems involving seesaws and lever systems.
Parents assisting children with physics homework, educators teaching basic physics concepts, and students learning about mechanics and equilibrium in physical systems.
Forgo
She has to figure out where to place a second kid on a seesaw to balance the seesaw. They give you the weight of the seesaw in the problem. Is this relevant? Or do you ignore the weight of the seesaw?
If you place the pivot exactly halfway between the board, and assuming the board is uniform in mass/density, then the force of it's weight will act right on the pivot so it won't cause a torque.. meaning you can pretty much exclude it from the equation
Thanks.
14K
