Understanding Electric Flux and Its Physical Significance: Gauss' Law Confusion
The discussion revolves around the concept of electric flux, its definition, physical significance, and its relationship with electric field strength and charge. Participants explore theoretical aspects, definitions, and units related to electric flux, as well as its comparison with magnetic flux.
  • Some participants define electric flux as the number of electric field lines per unit area, while others argue that it corresponds to the total number of field lines piercing a surface, regardless of area or angle.
  • There is a discussion about the arbitrary nature of field lines and how they relate to the actual physical quantities involved, with some suggesting that the concept of field lines is merely a visual aid.
  • Some participants propose that the unit of electric flux is coulombs, while others suggest it is defined as the product of electric field strength and area, leading to confusion regarding its units.
  • There is a debate about whether electric flux should be defined in a way that is analogous to magnetic flux, with some expressing dissatisfaction with historical definitions that have led to inconsistencies.
  • Participants question the definitions of electric flux and electric displacement, noting potential semantic issues and the existence of different interpretations in various sources.
Participants express differing views on the definition and significance of electric flux, with no consensus reached on whether there are multiple definitions or how they should be interpreted. The discussion remains unresolved regarding the relationship between electric flux and electric displacement.
Limitations include the ambiguity in definitions of electric flux and electric displacement, as well as the dependence on historical context for the units used. Some mathematical relationships and assumptions about field lines are also not fully resolved.
aalmighty
The electric flux, by a definition, is the number of electric field lines per unit area. Yet, when we apply gauss' law for a 1 Coulumb charge, we get a non-integral value. What then, is the physical Significance of the value we get?
Electric field lines are just visual aides for picturing the field. The actual number of field lines emanating from a point charge is arbitrary, but will be proportional to the charge. The field strength will be proportional to the density of field lines; flux would be a number of lines passing through an area.
Rather than get hung up on counting field lines, think in terms of the actual field strength.
in addition, since the Coulomb is a completely artificial and human-defined unit of charge, if there ever was a real physical reality to these "field lines" (there isn't, as Doc said, it's a visual aid to visualize flux density and why it is an inverse-square phenomenon), the number of lines would certainly not care about with what units humans decided measure charge with.
perhaps, instead, try to think of each electron or proton in that Coulomb of charge emitting a field line (say, for each electron or proton, having the direction of the field line be totally random, so that all directions are equally covered). then, as you draw successive concentric spheres around that coulomb of charge, you can see the density of field lines getting lower according to the inverse square law.
No. In the "field lines" picture, the magnitude of the electric field (i.e. its "strength" or "intensity") corresponds to the number of field lines that pierce a unit area oriented perpendicular to the field. The flux of the electric field through a surface corresponds to the total number of field lines that pierce the surface, regardless of the area of the surface or the angle that the lines make with respect to the surface.
The flux of the electric field through a surface is defined as
[tex]\int {\vec E \cdot \hat n dA}[/tex]
where the integral is taken over the surface and [itex]\hat n[/itex] is the unit vector perpendicular to the surface at each point. If [itex]\vec E[/itex] is perpendicular to the surface, and has the same magnitude, everywhere on the surface, then the flux is just the magnitude of [itex]\vec E[/itex] times the area of the surface.
So... what is the unit for electromagnetic flux?
boy, was this a stale thread?
the unit for electrostatic flux density would be unit of charge per unit of area (length^2). in SI, it would be "coulombs per meter squared". if you multiply that by [itex]1/\epsilon_0[/itex], you get the electric field (volts/meter), which if you multiply by the remote charge (coulombs), you get the force (Newtons).
oh, but you were asking about "flux", not flux density. the total flux that's emanating from the charge Q, is Q. that's distriibuted across a surface area [itex]4 \pi r^2[/itex] to give you a flux density of [itex]Q/(4 \pi r^2)[/itex] and is the origin of the inverse-square law for 3-dim space.
Is there such a thing as electromagnetic flux? There is electric flux and magnetic flux, but electromagnetic?
Electric flux is defined as the product of the electric field strength and the area.
So the unit is V/m * m^2 = V*m.
If you compare that with magnetic flux you can easily get confused as magnetic flux has the unit Vs. Therefore you might expect electric flux to be As, but that is not true because electric flux is defined completely different then magnetic flux.
In other words - electric flux is not the electric equivalent of magnetic flux.
Of course magnetic and electric flux should have been defined in an equivalent way but that didn't happen and so - for historic reasons - we are stuck with these definitions.
no. that's off by a constant factor of [itex]\epsilon_0[/itex]. "flux density" is defined to be flux divided by area. but flux density, represented as this D vector, is not the same as field strength, represented as this E vector. the relationship between D and E is D=[itex]\epsilon_0[/itex]E. in SI units, the unit for electrostatic flux is coulombs. 5 coulombs of charge emit a total of 5 coulombs of electrostatic flux.
it's a matter of units. if you do it sort of like the cgs system, the units for electrostatic flux and field are the same, but there's a dimensionless factor of [itex]4 \pi = 1/\epsilon_0[/itex] between them. and, in the Lorentz force equation, the E field and B field are the same units.
Was he talking about flux due to electric displacement or electric field?
Strange. Whereever I look - books, wikipedia, even online lectures from the MIT website - it says that electric flux is E*A.
Are there 2 different definitions of electric flux? E*A and D*A?
well, i guess there are semantic issues. i looked it up at Wikipedia and they use both "flux density" and "displacement field". if you consider the simple Coulombs inverse-square law:
[tex]F = \frac{1}{4 \pi \epsilon_0} \ \frac{Q \ q}{r^2}[/tex]
and consider this F to be the force that charge Q is exerting on charge q (it's also the force that q exerts on Q), then the electric field (created by Q) at the location where charge q is, is the force per unit charge
[tex]E = \frac{F}{q} = \frac{1}{\epsilon_0} \ \frac{Q}{4 \pi r^2}[/tex]
that E field is in units Newtons/coulomb (which is the same as volts/meter).
the latter factor [itex]Q/(4 \pi r^2)[/itex] is what i meant as "flux density". imagine a sphere centered at location Q with radius r, so that charge q sit on the surface of that sphere. the effect of that charge Q, which doubles if Q doubles, is distributed over the surface area of that sphere. if we call the constant of proportionality of that "effect due to charge Q" to be 1, and we call that the flux emanating from charge Q, then the total flux is simply Q. that total flux is divided among an area of [itex]4 \pi r^2[/itex] (which is what q can sense).
that is what that "D" quantity is. but our freedom to arbitrarily call that constant of proportionality "1" does not extend as far as the field strength, E. then we need to multiply by [itex]1/\epsilon_0[/itex], both to get our units right (and to get the right value in terms of those units). personally, i wish that both cgs and Planck Units chose their unit of charge so that it was [itex]\epsilon_0[/itex] was normalized to 1 rather than normalizing [itex]4 \pi \epsilon_0[/itex] as they did. if they did that, flux density (D) and field strength (E) would be exactly the same thing in a vacuum, measured in the same units and being the same value. but they didn't do that.
shucks.
You said that "Electric flux is defined as the product of the electric field strength and the area.
So the unit is V/m * m^2 = V*m."
every ehere i see electric flux is defined as E*A.Where did you get it as D*A?
If you are in a dielectric media, then the "displacement field" D is what you have to use. Since [itex]D=\epsilon E[/itex], it doesn't change the dimensional analysis.
Zz.
  • · Replies 30 ·
  • · Replies 25 ·
  • · Replies 83 ·
