Thread Closed
Magnetic Field and Electric field outside a long solenoid
Share Thread
Feb5-06, 01:40 PM   #1
Hello,
The question goes like this:
A long solenoid has n turns per unit length and carries a current given by I=I₀sinωt. The solenoid has a circular cross section of radius R. Find the induced electric field at a radios r from the axis of the solenoid for (a) r<R (b) r>R
Well, i got the first part as E=μRēNēωI₀cos(ωt)/(2Rl). Does this looks like it?
For the second bit, i found it as zero. But i am not really sure. And if it is zero, What should i say?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb7-06, 03:26 PM   #2
Hello there,
You'll have to excuse me because I'm not using the greek symbols.
(a) r<R,
int(E.dl)=-d(B.Area)/dt (definition of induced emf) take loop around
E.2*pi*r = -pi*(r^2)*mu*n*I*omega*cos(omega*t)
E= -(mu*n*I*omega*r*cos(omega*t))/2
is the induced field inside solenoid. Your answer is close but use r instead of R (since we are inside).
(b) r>R, outside
You are confusing with the case when magnetic field is zero outside long solenoid due to cancellations between field due to currents in successive & opposite loops.
In this case, (r>R...remember loop is longer)
E*2*pi*r = -pi*(R^2)*mu*n*I*omega*cos(omega*t)
(remember flux is over an area defined by pi*(R^2))
E = -(mu*n*I*omega*(R^2)*cos(omega*t))/ (2*r)
is the induced electric field outside.
Hope that helps,
Rama
Feb7-06, 03:54 PM   #3
Mentor
Are you sure they are asking about Electric fields? That doesn't make much sense. More often, you will be asked to solve for the magnetic field as a function of radius for the solenoid....
Feb11-06, 06:57 PM   #4
Yea, i m asked to find electric field. And i just found out this is one of the question found from the textbook. And yes, thats the correct answers! but i am still not sure why it is not zero. isnt that when theres no magnetic field, theres no electric field as well?
Feb11-06, 08:10 PM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
darkar,
To understand why there is an electric field outside the solenoid, just think about Faraday's Law. If you draw a loop around the solenoid, the magnetic flux through the loop is changing as a function of time, right? Even though there is no magnetic field outside the solenoid there is still a changing magnetic flux (from the field inside the solenoid). What does this tell you about the electric field?
Feb12-06, 10:59 AM   #6
Yea, thats amaze me. Why can there be magnetic flux but no magnetic field. So lif theres magnetic field, the magnetic flux is constant?
Thread Closed
Similar discussions for: Magnetic Field and Electric field outside a long solenoid
Thread Forum Replies
Magnetic Field outside a solenoid General Physics 4
electric field and magnetic field - proton deflection Introductory Physics Homework 6
Magnetic field in a semi-cut solenoid General Engineering 0
Magnetic field with solenoid, have work; need help Introductory Physics Homework 6
Magnetic Field outside AC Solenoid Electrical Engineering 2
