How is the kinetic energy of a falling rod on a frictionless surface calculated?
The kinetic energy (T) of a falling rod on a frictionless surface is calculated using the formula T = 1/8 M L^2 (sin²θ + 1/3) dθ/dt², where M is the mass, L is the length, g is the acceleration due to gravity, θ is the angle, and dθ/dt is the angular velocity. The moment of inertia (I) for the rod is I = M(L/2)². Additionally, the rate of change of the vertical position of the center of mass (dy/dt) is expressed as Y' = sinθ √((3gL(1 - cosθ)) / (4 - 3cos²θ)).
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with angular motion and angular velocity
  • Knowledge of gravitational effects on rigid bodies
  • Basic calculus for differentiation and function analysis
  • Study the derivation of kinetic energy for composite motion in rigid bodies
  • Learn about the conservation of energy in falling objects
  • Explore the relationship between angular and linear motion in physics
  • Investigate the effects of different angles on the motion of falling rods
Physics students, mechanical engineers, and anyone studying dynamics and motion of rigid bodies will benefit from this discussion.
dowjonez
A thin homogeneous rod hsa length L and mass M. Initially the rod is vertical at rest on a frictionless surface. The rod is given a slight push and begins to fall in the gravitational field.
1) write an expression for the kinetic energy T of the rod as functions of M,L,g, theta and d theta/dt
2) if y is the distance the center of mass drops. find d y/dt as a function of L, g and theta
#1)i know the Kinetic energy of the rod is given by the equation
T= 1/2 I w^2
where w = omega = d theta/dt
and I = M(L/2)^2
so T = 1/2 M(L/2)^2 d theta/dt^2
T = 1/8 M L^2 d theta/dt^2
The answer is T = 1/8 M L^2 d theta/dt^2 (Sin^2theta + 1/3)
i don't know where the (Sin^2theta + 1/3) comes from
#2)
i don't even know where to start on this one
but the answer is Y prime = sintheta sqrt ( (3gL(1-costheta) / 4-3cos^2theta)
any help would be greatly appreciated
T= 1/2 I w^2
That would be true if the rod were purely rotating, but it's also translating: the total KE is the sum of the translational KE (of the cm) and the rotational KE (about the cm).
  • · Replies 18 ·
  • · Replies 16 ·
