3 x 3 Matrices, and solving a series of equations.
  • Thread starter Thread starter finchie_88
    Matrices Series
The discussion revolves around solving a system of equations represented by a 3 x 3 matrix and determining the geometric interpretation of the solutions, specifically whether the equations form a prism. The original poster expresses familiarity with matrix methods but seeks clarification on identifying prisms from the equations.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the relationships between the equations and their geometric representations as planes. There is discussion on the conditions under which the equations form a prism, including the analysis of parallel lines of intersection and the consistency of the equations.
Participants are actively engaging with the problem, sharing insights about plotting the equations and analyzing their intersections. Some guidance has been provided regarding the conditions for forming a prism, although there is no explicit consensus on the best approach to determine this from the equations alone.
There is mention of the augmented matrix and pivot positions, indicating a focus on linear algebra concepts. The original poster's experience level with matrices is noted, suggesting a learning context.
finchie_88
I can solve equations using matrices (finding the inverse method etc), and in my textbook at the moment it sometimes gives questions where the determinant is zero,I understand what that means, and I can spot whether the equations are inconsistent, the same thing (just multiplied by a number), or several distinct lines, but sometimes, they form prisms. My question is: how can you tell from the equations that they form a prism?
Here is an example question from my book...
Solve:
[tex]\left(\begin{array}{ccc}1&1&1\\2&3&-4\\5&8&-13\end{array}\right)[/tex]x[tex]\left(\begin{array}{c}x&y&z\end{array}\right)[/tex]=
[tex]\left(\begin{array}{c}4&3&8\end{array}\right)[/tex]
edit: Sorry about thedodge matrices, its my first time doing them.
I was curious about this question, so ...
The eqns are,
x + y + z = 4 ------------------(1)
2x + 3y - 4z = 3 ---------------(2)
5x + 8y - 13z = 8 --------------(3)
I plotted these three eqns as planes and found that they do form a prism.
Then I noticed that the lines of intersection of the three planes all looked parallel.
I then took each pair of planes to find the line/plane of intersection.
(2) - 2*(1) gives,
y - 6z = -5 -------------(4)
(3) - 5*(1) gives,
3y - 18z = -12
y - 6z = -4 -------------(5)
5*(2), 2*(3) gives,
10x + 15y - 20z = 15 ------------(6)
10x + 16y - 26z = 16 ------------(7)
(7) - (6) gives,
y - 6z = 1 -------------(8)
The lines (or planes) (4), (5) and (8) all have the same slope (y=6z), and so are all parallel.
So, I don't think you can tell if a set of eqns form a prism just by casual observation, but if you do a little work on them, to show that they the intersecting planes all have the same "slope", then that should show that these eqns form a prism.
HTH
Thank you for the help. It is greatly appreciated.:biggrin:
You said that you plotted the planes, did you do that using a computer? (If you didn't, you must have some good art skills).
Yeah, I plotted them on my computer. :smile:
I used Autograph.
Well, they will form a "prism" if any 2 rows of the augmented matrix are consistent with each other, but all 3 together are not. This will happen when there are exactly 3 pivot positions in the augmented 3x4 matrix, and one of the pivot positions is in column 4.
