| Thread Closed |
Naming Ionic Compounds |
Share Thread | Thread Tools |
| Feb6-06, 03:59 PM | #1 |
Why is NO2 called nitrite? I'm going over this again and I'm still confused.
Part 1: Cations Group 1A and 2A cations are given the name of the metal plus the word "ion." Example: Mg 2+ is called a "magnesium ion." Some metals form more than one kind of cation as we saw in the last section. This is often true of transition metals. To distinguish the different charges of a cation, Roman numerals are added in parentheses to the element name. Example: Iron has two possible charges when ionized: Fe 2+ and Fe 3+ . These are named respectively Iron(II) and Iron(III). Notice that there is no space between the name and the left parenthesis. Got that... Part 2: Anions Single-atom anions (nonmetals) are named by replacing the -ine ending of the element with -ide. Example: Chlorine becomes Cl - when it ionizes. Its name changes from chlor ine to chlor ide. ...and that...but this... B. Polyatomic ("many atom") ion names must be memorized. A table of these ions is below. Most of the polyatomic ions are anions. I highly suggest you print this table and keep it handy in your notebook. ...can't memorize them if you don't understand them. I'm reviewing and this is one of the things I need to relearn as it's obviously causing me a lot of trouble. My text book doesn't seem to have anything on it and that's all that's in the lesson. |
| Feb6-06, 06:21 PM | #2 |
Recognitions:
NO2 is called Nitrogen Dioxide.
NO2- is the nitrite ion. I dont think there is a reason for why the ion has that name (other than the [i]Nitr[/i[] in Nitrogen). You just need to memorize the names of the common polyatomic ions. |
| Feb6-06, 08:56 PM | #3 |
[itex][NO_3]^-[/itex] = Nitrate
[itex][NO_2]^-[/itex] = Nitrite [itex][SO_4]^{-2}[/itex] = Sulfate [itex][SO_3]^{-2}[/itex] = Sulfite The polyatomic ion with the most oxygen ends in -ate while the one with the least oxygen ends with -ite. Here is how it works if there are more than two ions in a "group" : [itex][ClO_4]^-[/itex] = Hyperchlorate [itex][ClO_3]^-[/itex] = Chlorate [itex][ClO_2]^-[/itex] = Chlorite [itex][ClO]^-[/itex] = Hypochlorite Do you catch the general pattern? |
| Feb6-06, 11:52 PM | #4 |
Recognitions:
Naming Ionic Compounds[itex][ClO]^-[/itex] = Hypochlorite [itex][ClO_2]^-[/itex] = Chlorite [itex][ClO_3]^-[/itex] = Chlorate [itex][ClO_4]^-[/itex] = Perchlorate I'm not sure if it's entirely true, but it seems to hold true from what I've seen. Phosphorus tries to form phosphates, sulphur tries to form sulphates, nitrogen tries to form nitrates. Chlorine may be an exception since chlorate is very reactive. |
| Feb7-06, 01:27 PM | #5 |
Alright, I'm starting to piece some of this together but I'm still a bit confused...the chart on the lesson page says, copied and pasted here, :
NO2 - nitrite NO3 - nitrate ...not... NO2 - Nitrogen Dioxide What about this? This one is a bit longer than the other ones... HSO4 - hydrogen sulfate or bisulfate |
| Feb7-06, 01:47 PM | #6 |
| Feb7-06, 02:00 PM | #7 |
I'm not following, sorry... ^_^
| Feb7-06, 02:09 PM | #8 |
Recognitions:
HSO4- is the biSulfate ion, or Hydrogen Sulfate under the new naming system (I am old, so I like the old ways best).
SO4-2 is the Sulfate ion, so after adding a Hydrogen, it becomes Hydrogen Sulfate with a new charge. [Sulfuric acid, H2SO4 dissassociates in water to form H+ and HSO4- ions which will further dissasscociate to form SO4-2 ions and more H+ ions.] |
| Feb10-06, 11:11 AM | #9 |
take [tex]NaCl[/tex] for example. Its trivial name is "salt", "table salt" and so on, while its systematic name is sodium chloride. The same goes for [tex]NO_2[/tex]. Its trivial name is nitrite but its systemativ name is nitrogen dioxide. It is often easier to remember the systematic name of an ion because it follows the same pattern. 2 atoms makes di, three makes tri- and so on. |
| Feb10-06, 11:00 PM | #10 |
Aw, that is easier...nothing is ever easy anymore...
| Thread Closed |
| Thread Tools | |
Similar Threads for: Naming Ionic Compounds
| Naming benzene compounds | Biology, Chemistry & Other Homework | 1 | ||
| Naming compounds | Biology, Chemistry & Other Homework | 6 | ||
| Naming Organic Compounds | Biology, Chemistry & Other Homework | 1 | ||
| naming organic compounds help plzzz | Biology, Chemistry & Other Homework | 1 | ||
| Naming Nonorganic Compounds | Chemistry | 1 | ||
