What is the magnitude of the electric field at P2?
The discussion revolves around calculating the magnitude of the electric field at point P2 due to a dipole. The original poster attempts to apply an equation for electric fields but struggles with its application to P2, seeking clarification on the variables involved.
  • Participants discuss the validity of the approximation used for P1 and its applicability to P2. Questions arise regarding the correct angle to use in the formula and the interpretation of the variables in the context of the dipole's position.
Some participants provide insights into the limitations of the original equation and suggest using Coulomb's law for a more accurate calculation. There is ongoing exploration of the correct parameters and assumptions needed for the calculation at P2, with no clear consensus reached yet.
Participants note the importance of understanding the coordinate system and the specific conditions under which the formulas apply. There is mention of a specific charge value provided in the text, which contrasts with values used by the original poster.
hoseA
http://img79.imageshack.us/img79/2859/dipoleelectricfield5nh.png
I used the equation E= kqd/(L^3)
L=sqrt(h^2+(d/2)^2)
I got the first answer (for P1).
I can't figure out how to utilize that equation for P2.
The second question asks:
"What is the magnitude of the electric field at
P2? Answer in units of N/C"
what's the value of L (-100... -101.1 or something totally different)... I don't quite understand the variables in the given equation. Help is most appreciated. thx.
The formula you used to calculate P1 is an approximation that is only as precise as the field you calculate is far from the dipole (we say the approximation is valid at large distances). It is useful when the charge distribution we want to calculate is weird (but of charge 0 C in total) and hard to calculate. 100 meters is a reasonably large distance and the use of the approximation would be justified in practice. However, you have all the necessary information at your disposal to evaluate the field exactly.
All you need is Coulomb law.
Note: For P2, the equation you used to approximate P1 is not applicable. In fact, the equation you used is only valid to approximate the field for points on the plane perpendicular to your computer screen and perpendicular to the line joining the charges and such that P1 is a point of that plan. (This defines the plan uniquely) For points in other locations in space, you must use the more general formula
[tex]\vec{E}(r, \theta) = \frac{kqd}{L^3}(2 \cos\theta \ \hat{r} + \sin\theta \ \hat{\theta})[/tex]
where the dipole vector [itex]\vec{p}=q\vec{d}[/itex] is located at the origin and points in the direction of the positive z axis. theta is the polar angle from spherical coordinates that is restricted to [0,pi] (as opposed to [itex]\phi[/itex] that ranges from 0 to 2 pi).
Does that mean i substitute pi as the angle (which essentially means 2cospi * sin pi = -2?)
And L= -100^3 and d=1.1 ? correct?
You mean, supposing you wanted to apply that formula to approximate the field at P2? Then no, the angle to use would be 0. Because since the direction of p defines the positive z axis, P2 is on the positive z axis. But for points along the positive z axis, theta = 0. So the formula boils down to
[tex]\vec{E} = \frac{kd}{L^3}(2\hat{z})[/tex]
And since using this formula implies choosing a coordinate system such that the vector p is resting at the origin, then L would be 100+d/2.
Assuming u forgot the q,
I tried (kqd/L^3)*2 = 7.24951 (this came up as wrong)
I also tried without the q = 1.768174e6.
i substituted (100+(d/2)) for "L".
What am I doing wrong? Thanks for the help.
any help within the next 10 min. much appreciated. I only have 1 try left. Is there supposed to be a "q" in the equation or is what quasar put correct? thanks.
I missed a q yes.
You used q = 1.768174e6? Where does that come from? The text tells you q = 4.1 µC.
  • · Replies 0 ·
  • · Replies 23 ·
