Problems using photon's energy to calculate electron's velocity
  • Thread starter Thread starter mgeoghe2
    Energy Velocity
The discussion focuses on calculating the velocity of the fastest electron ejected from a tungsten surface when illuminated by light with a photon energy of 5.8 eV, given a work function of 4.5 eV. The kinetic energy of the ejected electron is determined using the equation KEmax = hf - work function, leading to KEmax = 5.8 eV - 4.5 eV = 1.3 eV. To find the velocity, the mass of the electron (9.109e-31 kg) is used in conjunction with the equation v^2/c^2 = 2 * KE/mc^2, where c is the speed of light.
  • Understanding of the photoelectric effect and work function
  • Knowledge of kinetic energy equations
  • Familiarity with electron mass and energy units (eV, kg, MeV)
  • Basic grasp of relativistic equations
  • Study the photoelectric effect in detail, focusing on the role of work function
  • Learn how to convert between energy units (eV, MeV, Joules)
  • Explore relativistic effects on electron velocity calculations
  • Practice problems involving kinetic energy and electron dynamics
Physics students, educators, and anyone interested in quantum mechanics and the photoelectric effect will benefit from this discussion.
mgeoghe2
ive got this problem in which i am given:
the work function of tungsten = 4.5 eV
light with photon energy 5.8 eV illuminates surface
and i need to figure out what the velocity of the fastest electron ejected from the surface is.
so i see work function and 'fastest' and i think, ok KEmax = hf - work function. and KE is just .5mv^2. the problems i run into are these:
where do i get f? or hf?
i see that E = hf , so i think, ok i will use 5.8 -4.5 = KEmax. but then i run into another problem.
which mass do i use? i got really screwed up with the units... i can use 9.109e-31 kg but i don't know if and eV is kg m^2/s^2. i am also given the mass of an electron as .511 MeV/c^2 but i don't really understand what that means. is it .511e6 or .511e6/(3e8)^2??
if you have any insightful comments, i would be very grateful.
Since you know the rest energy of electron you can find the speed from
[tex]\frac {v^2}{c^2} = \frac {2 \times 1.3 eV}{m c^2}[/tex]
13K
30K
