Model that demonstrates conservation of mechanical energy
The discussion revolves around selecting or creating a model to demonstrate the conservation of mechanical energy for a physics project. Participants are exploring various options that can be easily constructed and effectively illustrate this principle.
  • Exploratory, Problem interpretation
  • Participants suggest different models such as a spring and ball, and a roller coaster, while also discussing restrictions on previously mentioned models like the balance ball and pendulum. There are inquiries about the feasibility and complexity of these models.
The conversation is ongoing, with several suggestions being made. Some participants are seeking clarification on the proposed models, while others are considering the practicality of constructing them with common materials. No consensus has been reached yet.
Participants are limited to using models that are not overly complex and can be made from normal household items. There is a specific restriction against using the balance ball model.
furia
My physics class is currently invovled with a project regarding conservation of mechanical energy.
I will need to choose or create a model that will demonstrate conservation of mechanical energy, then analyze the model and explain it.
Does anyone know of any model that can be made easily and can demonstrate conservation of mechanical energy in a simple way, such as the balance ball, or pendulum.
( The balance ball and pendulum are restricted models of this project)
How about a spring and a ball?
Or maybe those cool toys with several metal balls suspended on V-strings all lined up and touching, where you pull one out at one end and let go, and when it hits it knocks out the ball on the other end out to the same max height? Those are fun, and may be different enough from a standard 1-ball pendulum that your instructor will allow it.
spring and ball, please go in abit further on that. the balls on v string is also known as the balance ball, so i can't use that
By spring and ball, I think Pseudo means a mass on the end of a spring. If you can't use the balance ball, how about a roller coaster? Once you get towed to the top of the first big hill, it's all PE<-->KE from there on down. Maybe even add in some of the upside-down corkscrew sections...
maybe something like that, not too complicated or i won't be able to make it out of normal house stuff
