How much energy would neon gas absorb to increase the temperature
The discussion focuses on calculating the energy absorption of 180 g of neon gas to achieve a temperature increase of 12 K, utilizing the formula involving mass, specific heat, and temperature change. Additionally, it covers the construction of P-V diagrams for isobaric and isothermal processes, as well as cyclic processes involving isochoric and isobaric steps. Lastly, it addresses the calculation of the highest possible exhaust temperature for an engine operating at 27% efficiency and 420°C, referencing Carnot efficiency principles.
  • Understanding of thermodynamic processes, specifically isobaric, isothermal, and isochoric processes.
  • Familiarity with the concept of specific heat and its application in energy calculations.
  • Knowledge of P-V diagrams and their significance in thermodynamics.
  • Comprehension of Carnot efficiency and its relation to hot and cold temperatures.
  • Calculate energy absorption for different gases using specific heat formulas.
  • Learn to construct and interpret P-V diagrams for various thermodynamic processes.
  • Explore the principles of Carnot efficiency and its applications in real-world engines.
  • Investigate the relationship between temperature, pressure, and volume in ideal gases.
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in energy systems and engine efficiency analysis.
truckerron1
i have 3 questions that i need help with
Consider 180 g of neon gas. How much energy would it have to absorb to experience a temperature increase of 12 K?
Construct a PV diagram for each of the following. (a) A gas begins with a volume of 14 L under pressure of 3 atm. The gas first undergoes an isobaric compression to a volume of 6 L. Next, the gas experiences an isothermal expansion back to a volume of 14 L. (b). A gas undergoes a cyclic process consisting of two isochoric processes and two isobaric processes.
A particular engine having efficiency 27% operates at temperature 420C. What is its highest possible exhaust temperature?
thanks ron
One needs to show one's work before requesting help.
However, some hints:
1. The energy is related to the mass, the specific heat and the change in temperature. An example should be found in one's textbook.
2a. P-V diagrams are fairly straight forward. The problem starts with a known state point, P, V. Isobaric means 'constant' pressure, and on is given the new volume of 6L. Isothermal is constant temperature, so one needs to find the relationship of P and V for an isothermal expansion.
Isobaric process - http://www.pha.jhu.edu/~broholm/l35/node4.html
Isothermal process - http://www.pha.jhu.edu/~broholm/l35/node3.html
2b. An isochoric process, also called an isometric process, is a thermodynamic process in which the volume stays constant; ΔV = 0.
See - http://en.wikipedia.org/wiki/Isochoric_process
and - http://www.pha.jhu.edu/~broholm/l35/node2.html
3. Find the definition of Carnot efficiency as a function to the hot and cold temperatures, Thot and Tcold, respectively.
  • · Replies 67 ·
  • · Replies 21 ·
