Some Electric Potential energy questions
The discussion revolves around electric potential energy and the motion of charges in an electric field. The original poster presents a problem involving two charges, their positions, and the calculation of speed as one charge moves infinitely far from another.
  • The original poster attempts to break down the problem into components and calculate forces and electric fields, but expresses uncertainty about their results. Participants question the correctness of the approach and the understanding of potential energy and electric potential.
Participants are engaged in clarifying the concepts of electric potential and potential energy. Some have offered hints regarding the potential at infinity and the formulas involved, while the original poster is seeking further assistance to resolve their confusion.
The original poster mentions using an online platform (webassign) for submitting answers, indicating that they are working under specific constraints related to the problem's requirements.
wr1015
A charge of 3.19 µC is held fixed at the origin. A second charge of 3.19 µC is released from rest at the position (1.15 m, 0.530 m) .
(a) If the mass of the second charge is 3.10 g, what is its speed when it moves infinitely far from the origin?
ok so I've broken it up into x and y components and used pythagorean theorem to find the line that represents the force that the second charge exerts on the fixed charged [tex]\sqrt{1.15^2 + .530^2}[/tex] and my answer was 1.266 m. Then i used tan[tex]^-1[/tex] (.530/1.15) to find theta which came out to be 11.98[tex]^0[/tex]. Then i calculated 1.266 (cos 11.98) for the positive x-direction and 1.266(sin 11.98) for the positive y-direction and i got 1.2384 m for the x and .26278 m for the y. Then i plugged those values back into pythagorean theorem again to find the net force [tex]\sqrt{.26278^2 + 1.2384^2}[/tex] and got 1.2666N. Then i used the Force per unit charge to find the net electric field and got (1.2666/3.19E-6) = 3.97E5 and multiplied by 2 since there are 2 charges and got 7.94E5 as my net electric field. And then i plugged that value into [tex]\sqrt{2q\Delta V/m}[/tex] to find velocity. Obviously I'm doing something wrong somewhere because I'm not getting the right answer... any help would be greatly appreciated.
What's the right answer ?
Hint : what is the potential if the charge is that far away from the first charge.
marlon
marlon
well that's what I'm trying to figure out..
Well,
what's the forumula for the potential ?
Again, what's the right answer ? You told in your first post that you keep getting the wrong answer ? How do you know this ?
marlon
marlon said:
Well,
marlon
formula for potential is [tex]\Delta U/q[/tex] but don't you have to figure out net electric field first since [tex]\Delta U = qEd[/tex] ??
i'm using webassign so the answers i keep entering are wrong
The formula for the potential of a charge q felt at a distance r is [tex]U = k \frac{1}{r}[/tex] where k is a constant that does not matter here. Now, what's the U if q is at spatial infinity ?
It is important to understand the concept of potential (which is the aim of your exercise). A potential is actually potential energy per unit of electric charge. So two electric charges q1 and q2 have potential energy [tex]k \frac{q1*q2}{r}[/tex] where r is the distance between those two charges. If you divide this expression by, let's say, q1 you get the potential of q2. This potential, actually is a measure of how big the interaction (ie the magnitude of the potential energy) with an electrical charge will be if you put some charge q1 on a distance r from q2.
marlon
marlon
thank you for your help, i understand now..
  • · Replies 20 ·
