| Thread Closed |
summation |
Share Thread | Thread Tools |
| Feb14-06, 04:39 PM | #1 |
summation
I am to show that...
[tex]\sum_{n=-N}^{+N} cos(\alpha -nx)=cos\alpha \frac{sin(N+0.5)x}{sin(x/2)}[/tex] [tex]\sum_{n=-N}^{+N} cos(\alpha)cos(nx)+\sum_{n=-N}^+Nsin(\alpha)\frac{sin(N+0.5)x}{sin(x/2)}[/tex] [tex]\sum_{n=-N}^{+N}sin(\alpha)\frac{sin(N+0.5)x}{sin(x/2)} =0[/tex] [tex]cos(\alpha) 2 \sum_{n=0}^{+N} cos(nx)[/tex] I know of a rule that shows... [tex]\frac{1}{2}+cos(x)+cos(2n)+...cos(nx)=\frac{sin(N+0.5)x}{2sin(x/2)}[/tex] but I dont see how to apply it to get my answer, since my summation is similar to equation (9) on this site: http://mathworld.wolfram.com/Cosine.html any ideas? |
| Feb14-06, 07:01 PM | #2 |
I think you've messed up in stating your problem -- it doesn't really make sense.
Anyways, you know trig identities, right? You could try applying some of them. Or, you could always grind through an inductive proof. |
| Feb15-06, 01:22 AM | #3 |
oh wow, i totally messed up there...
[tex]\sum_{n=-N}^{+N} cos(\alpha -nx)=cos\alpha \frac{sin(N+0.5)x}{sin(x/2)}[/tex] [tex]cos(\alpha -nx) =cos(x)cos(nx)+sin(\alpha)sin(nx)[/tex] [tex]\sum_{n=-N}^{+N} cos(\alpha)cos(nx)+\sum_{n=-N}^{+N} sin(\alpha)sin(nx)[/tex] [tex]sin(\alpha) \sum_{n=-N}^{+N} sin(nx)=0[/tex] since it is an odd function so I am left with... [tex]cos(\alpha) 2 \sum_{n=0}^{+N} cos(nx)=cos\alpha \frac{sin(N+0.5)x}{sin(x/2)}[/tex] [tex]2 \sum_{n=0}^{+N} cos(nx)=\frac{sin(N+0.5)x}{sin(x/2)}[/tex] there is a rule that shows: [tex]\frac{1}{2}+cos(x)+cos(2n)+...cos(nx)=\frac{sin(N+ 0.5)x}{2sin(x/2)}[/tex] I am stuck on this part and I dont know where to go from here. |
| Feb15-06, 09:06 AM | #4 |
summation |
| Feb15-06, 09:56 AM | #5 |
Recognitions:
You are wrong when assuming that: [tex]\cos \alpha \sum_{n = -N} ^ {+N} (\cos (nx)) = 2 \cos \alpha \sum_{n = 0} ^ {+N} (\cos (nx))[/tex] In fact, it should read: [tex]\cos \alpha \sum_{n = -N} ^ {+N} (\cos (nx)) = 2 \cos \alpha \sum_{n = 1} ^ {+N} (\cos (nx)) + \cos \alpha \cos (0n) = 2 \cos \alpha \sum_{n = 1} ^ {+N} (\cos (nx)) + \cos \alpha[/tex] [tex]= \cos \alpha \left( 1 + 2 \left( \sum_{n = 1} ^ {+N} \cos (nx) \right) \right)[/tex]. Now you can go from here, right? Hint: follow Hurkyl's suggestion. :) |
| Feb15-06, 11:35 AM | #6 |
[tex]\frac{sin(N+ 0.5)x}{2sin(x/2)}=-\frac{1}{2}+\sum_{n = 1} ^ {+N} \cos (nx) [/tex]
so now everything fits into place! Just out of curiosity, how would someone derive: [tex]\frac{1}{2}+cos(x)+cos(2n)+...cos(nx)=\frac{sin(N+ 0.5)x}{2sin(x/2)}[/tex]? |
| Feb15-06, 11:44 AM | #7 |
Recognitions:
Use [tex]\cos(z)=\frac{e^{iz}+e^{-iz}}{2}[/tex] to turn it into a geometric sum.
| Feb15-06, 11:50 AM | #8 |
Induction works too.
| Feb15-06, 11:53 AM | #9 |
i've found an example in mathworld but it isnt the sum from 1 to infinity, but from 0 to infinity: http://mathworld.wolfram.com/Cosine.html how is it possible that their cosine on the numerator is cancelled out to form [tex]\frac{sin(N+0.5)x}{sin(x/2)}[/tex] when the summation is changed from (0 to inifinity is what they have) to 1 to infinity? |
| Feb15-06, 12:25 PM | #10 |
Recognitions:
There won't be an imaginary part.
The sum on mathworld, (9)-(13) I guess you mean, is a little different from yours (note it doesn't go to infinity). You both have a term for n=0, but yours is half theirs and your argments for the sin in the numerator are different. Their method of derivation is essentially what I suggested (though they should have said something about the x=integer multiple of 2*pi case). You might want to work with yours in the form [tex]\sum_{n = -N} ^ {+N} \cos (nx)[/tex] though. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: summation
| Summation | Calculus & Beyond Homework | 2 | ||
| Help with summation | Calculus & Beyond Homework | 10 | ||
| Summation of S(N)? | Linear & Abstract Algebra | 7 | ||
| Can the summation....... | Introductory Physics Homework | 17 | ||
| Summation | Introductory Physics Homework | 13 | ||
