Vectors, New Student, probably very basic
  • Thread starter Thread starter stevie
    Student Vectors
The discussion revolves around a physics problem related to vectors, specifically the motion of a stone thrown horizontally with an initial velocity. The problem involves determining the magnitude and direction of the stone's velocity after a specified time, considering gravitational acceleration and ignoring friction.
  • Participants discuss the initial conditions of the problem, including the horizontal throw and the effects of gravity. There is an exploration of the vector components involved, with some participants noting the need to separate the horizontal and vertical motions. Questions arise regarding the interpretation of the initial velocity and the application of vector equations.
Some participants have provided equations for calculating the components of motion, while others have pointed out potential misunderstandings regarding the initial conditions. There is a recognition of the need to convert Cartesian coordinates to polar coordinates for the final answer, and some guidance has been offered regarding the calculations involved.
Participants note that the problem may involve typographical errors in the provided answers, leading to further discussion about the correct interpretation of angles and magnitudes. The original poster expresses uncertainty about the question itself, indicating a possible lack of clarity in the problem statement.
stevie
I have just started studying my first physics class this year, and I am stuck on 1 question relating to vectors. I think my problem is understanding the question, I have completed all the other questions in the section fairly easily. This is the question I am stuck on.
A stone is thrown horizontally with an initial velocity of 5ms-1. What is the magnitude and direction of its velocity 0.2s later? Take the acceleration of free fall to be 9.8ms-2 and ignore friction.
The book has the answers, but it doens't show working out. but I have not been able to figure out how to do this one. Any help? Please? Show any workings. Thanks.
[tex]v_o = 5 m/s[/tex]
[tex]t = 0.2 s[/tex]
[tex]a = g = 9.82 m/s^2[/tex]
The [tex]v_0[/tex] is a vector upwards while the acceleration is a vector downwards with respect to the time.
No, it's horizontal. :smile:
The key here is to note that the vector equation
[tex]\vec v = {\vec v}_0 + \vec a t[/tex]
is really two equations, one each for the x and y components of motion:
[tex]v_x = v_{0x} + a_x t[/tex]
[tex]v_y = v_{0y} + a_y t[/tex]
The information you were given tells you the values of [itex]v_{0x}[/itex], [itex]v_{0y}[/itex], [itex]a_x[/itex], [itex]a_y[/itex] and [itex]t[/itex]. Therefore you can calculate [itex]v_x[/itex] and [itex]v_y[/itex], and from them you can calculate the magnitude and direction of [itex]\vec v[/itex].
The answer according to the book is "5.37ms-1, 2.14 degrees below horizontal."
Oh, my bad didn't read the whole question ;P
jtbell has the correct equations for each of the components (x and y). Keep in mind that the horizontal component has an acceleration of zero. The vertical component has an initial velocity of zero (the stone was thrown horizontally).
jtbell's equations give you the vector in Cartesian coordinates. You want the vector in polar coordinates. Plug the x and y coordinates into the Pythagorean Theorem to get the magnitude of the vector. The tangent of the angle is equal to y/x. (Since gravity accelerates the stone downwards, your y component will be negative, hence the negative angle - i.e. 2.14 degrees below horizontal).
Either you or the book made a typo. It should be 21.4 degrees, not 2.14.
  • · Replies 105 ·
  • · Replies 16 ·
  • · Replies 60 ·
  • · Replies 21 ·
