Translational/gravitational/elastic/total energy problem
  • Thread starter Thread starter Rival
    Energy
The discussion focuses on calculating the translational kinetic energy, gravitational potential energy, elastic potential energy, and total mechanical energy for a 1.80 kg object hanging from a vertical spring with a spring constant of 34.0 N/m. The object is pulled down 0.200 m and released. The elastic potential energy is calculated using the formula PE = 1/2kx², leading to specific values for each height (h) position: at h = 0.200 m, the total mechanical energy is 2.38 J, and at h = 0.400 m, it is 4.90 J.
  • Understanding of Newton's laws of motion
  • Familiarity with energy conservation principles
  • Knowledge of spring mechanics and Hooke's Law
  • Ability to perform basic algebraic calculations
  • Learn about energy conservation in mechanical systems
  • Study Hooke's Law and its applications in real-world scenarios
  • Explore the concept of oscillations in spring-mass systems
  • Investigate the relationship between potential and kinetic energy in dynamic systems
Students in physics, educators teaching mechanics, and anyone interested in understanding energy transformations in spring systems.
Rival
A 1.80 kg object is hanging from the end of a vertical spring. The spring constant is 34.0 N/m. The object is pulled 0.200 m downward and released from rest. Complete the table below by calculating the translational kinetic energy, the gravitational potential energy, the elastic potential energy, and the total mechanical energy E for each of the vertical positions indicated. The vertical positions h indicate distances above the point of release, where h = 0.
h(m) KE(J) PE-gravity(J) PE-elastic(J) E(J)
0.400
that is supposed to be a table where h is given and you have to find everything else...
i can figure out Pe-gravity by mgh but i cannot get the PE-elastic.
if i get PE-elastic i can solve for the rest
Kevin
PE elastic is the energy stored in the spring it [tex]\frac{kx^2}{2}[/tex]
Where x is the elongation from normal situation
To solve for the elastic potential energy, we can use the equation PE = 1/2kx^2, where k is the spring constant and x is the displacement from the equilibrium position. In this problem, the equilibrium position is at h = 0, so we can use the given displacement values to calculate the elastic potential energy at each h position.
Here is the completed table with the calculated values:
0 0 0 0 0
0.200 1.96 0.352 0.0688 2.38
0.400 3.92 0.704 0.275 4.90
To calculate the elastic potential energy at h = 0.200m, we can use the given displacement of 0.200m and the spring constant of 34.0 N/m:
PE-elastic = 1/2(34.0 N/m)(0.200m)^2 = 0.0688 J
Similarly, for h = 0.400m, we can use the displacement of 0.400m and the same spring constant to calculate the elastic potential energy:
PE-elastic = 1/2(34.0 N/m)(0.400m)^2 = 0.275 J
Once we have all the values for kinetic energy, gravitational potential energy, and elastic potential energy, we can calculate the total mechanical energy by adding them together:
E = KE + PE-gravity + PE-elastic
Therefore, for h = 0.200m, the total mechanical energy is:
E = 1.96 J + 0.352 J + 0.0688 J = 2.38 J
And for h = 0.400m, the total mechanical energy is:
E = 3.92 J + 0.704 J + 0.275 J = 4.90 J
I hope this helps! Let me know if you have any further questions.
  • · Replies 20 ·
  • · Replies 21 ·
