Thread Closed
Wheels and Crazy Spinning Things!!!
Share Thread Thread Tools
Dec17-03, 12:08 AM   #1
For the illustration of the following model, go to http://www.corniceventures.com/images/wheels.JPG
If the 2 wheels ("B1" and "B2") are the same diameter (40 inches) and are rolling forward at 4 miles per hour...Would belts "D1" and "D2" rotate hubs "C1" and "C2" respectively at the same rate (rpm's)?
Here are all the parameters:
"B1" and "B2" Diameter >> 40 inches
"A" Diameter >> 12 inches
"C1" and "C2" Diameter >> 1 inch
Here is what my calculations told me:
"B2" Circumference >> ~125.66 inches
"A" Circumference >> ~37.70 inches
"C1" and "C2" Circumference >> ~3.14 inches
"B2" RPMs at 4 MPH >> ~33.61 rpm
"A" RPMs at 4 MPH >> ~112.05 rpm
"C1" and "C2" RPMs at 4 MPH >> ~1344.54 rpm
To me it seems that belt "D2" would rotate hub "C2" more quickly than belt "D1" would rotate hub "C1" given the same forward speed, but maybe I should trust my calculations! Any help would be appreciated, thanks in advance!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Dec17-03, 03:48 AM   #2
Recognitions:
Gold Membership Gold Member
Both big wheels spin with ω = 4mph/40in. (convert that into rpm)
Assuming the belts don't slip:
ωA*rA = ωC1*rC1
and
ωB2*rB2 = ωC2*rC2
Note that ωA = ωB2 = ω
Rearrange to find one hub speed in terms of the other:
[latex] \omega_{C1} = \frac{r_A}{r_{C1}}\,\frac{r_{C2}}{r_{B2}}\omega_{C2} [/latex]
and since the hubs (C1 & C2) are the same size:
[latex] \omega_{C1} = \frac{r_A}{r_{B2}}\omega_{C2} [/latex]
So the hubs spin at different rates; since the radius (diameter) of B2 is greater than A, Hub C2 will spin faster than hub C1. So, your intuition was good, but there was some error in your calculations (I can't say where you went wrong without seeing your work). You should follow this line of thought out yourself to understand the idea and to double-check the algebra.
Thread Closed
Thread Tools
Similar Threads for: Wheels and Crazy Spinning Things!!!
Thread Forum Replies
spinning the wheels: intro to angular momentum Introductory Physics Homework 2
Spinning wheels and diamond wire fences General Physics 18
Spinning wheels of Global Warming Current Events 34
wheels keep spinning round Advanced Physics Homework 20
Crazy things General Discussion 13
