Friction Challenge: Increasing Speed?
  • Context: Undergrad
  • Thread starter Thread starter 'AQF
    Challenge Friction
The discussion revolves around the question of whether friction can increase the speed of a moving body, challenging the conventional understanding that friction typically acts to slow down motion. Participants explore various scenarios involving static and kinetic friction, as well as specific examples like sailboats and wedges.
  • Some participants suggest that static friction can accelerate an object under certain conditions, such as when one box is on top of another and an external force is applied to the lower box.
  • Others propose that kinetic friction might assist in accelerating an object in specific scenarios, like a wedge being accelerated rapidly, allowing a mass to move up the wedge against gravity.
  • A participant mentions that a sailboat can utilize kinetic friction (drag) to move faster when going downwind, although this raises questions about the definition of kinetic friction in this context.
  • One participant humorously notes that luggage on a conveyor belt speeds up due to friction, implying a practical observation of friction's role in acceleration.
  • Another participant discusses the potential for thermal motion in irregular surfaces to produce movement, suggesting a theoretical basis for acceleration from friction.
  • Concerns are raised about whether friction alone can cause motion, with some participants asserting that the sailboat example supports the idea that friction can contribute to movement.
  • There is a debate about the semantics of drag forces versus kinetic friction, with differing opinions on whether they can be classified similarly.
Participants express multiple competing views regarding the role of friction in acceleration, with no consensus reached on whether friction can independently cause an increase in speed. Some examples are accepted by certain participants while others challenge their applicability.
Participants highlight various assumptions and conditions under which friction might contribute to acceleration, but these remain unresolved and depend on specific scenarios and definitions.
'AQF
Can anyone think of a way where friction increases the speed of a moving body, instead of decreasing it? Or prove that this is impossible.
Well, in the case of STATIC friction, one might, if you wish, say that the static friction accelerates one of the bodies (think of two boxes on top of each other, the lower box receives an external force, whereas the top box is only influenced by the static friction between itself and the other box).
Is there any case where kinetic friction would help accelerate an object? For example, if a wedge is being accelerated at a very high rate, it is possible for the mass to travel up the wedge despite gravity. Would this be considered as speeding up?
[QUOTE='AQF]Is there any case where kinetic friction would help accelerate an object? [/QUOTE]
A sailboat.
Zz.
Can you expain this?
Everytime I drop my luggage on the conveyor at the airport it speeds up! :)
[QUOTE='AQF]Can you expain this?[/QUOTE] A sailboat going straight downwind essentially uses its sails as a big parachute - and that's kinetic/dynamic friction (drag).
[A sailboat going upwind (at an angle) uses lift.]
if the ground irregularities have a sawtooth appearance (microscopically speaking, of course) and the object which is on it also has this appearance in the interface, then it is possible in principle for the thermal motion to produce movement, which represents acceleration if you start with the object at rest.
Best Regards,
DaTario
In line with ZZ and Russ' answers, a car wouldn't accelerate very well without friction between the tires and the ground; that, however, sidesteps what I think might be the original question of friction alone causing movement.
Can friction alone cause motion, or is this impossible?
Please reread the answers you have already gotten. The sailboat example is a clear "yes" to your question.
[QUOTE='AQF]Is there any case where kinetic friction would help accelerate an object? For example, if a wedge is being accelerated at a very high rate, it is possible for the mass to travel up the wedge despite gravity. Would this be considered as speeding up?[/QUOTE]
Yes, I would say so. If you have an object on a surface. Let's say a plate on piece of fabric. And you pull violently on the clothing (to the right, say). I think that for a short time, the plate will be moving to the right (and sliding against the piece of fabric) and will be accelerating to the right. The fabric is moving faster than the plate, so in the frame of the piece of fabric, the plate is moving to the left with a kinetic friction acting to the right. But I think it's possible to pull the fabric with sufficient force that the plate will accelerate to the right due to the kinetic friction. But that's not based on an actual proof, just my intuition.
The example of the sailboat I think is a bit a stretch because no kinetic friction in the usual sense (due to two surfaces sliding against each other) is involved. I don't see how a drag force could be considered a kinetic friction force. This is all semantics, but that's my opinion.
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 29 ·
  • · Replies 45 ·
