Calculating Electric Field and Potential of a Charged Hollow Ball
The problem involves calculating the electric field and potential of a charged hollow ball with a uniform volume charge density. The original poster presents multiple questions related to applying Gauss's Law and determining electric potential energy and speed of a charge when released from a distance.
  • Participants discuss the application of Gauss's Law to find the electric field at specified distances from the center of the hollow ball. There is a question regarding the definition of the charge distribution as "hollow" versus "solid." The original poster contemplates equating electric potential energy to kinetic energy to find velocity.
Some participants have offered guidance on using Gauss's Law and integrating to find the charge inside a Gaussian surface. There is acknowledgment of potential confusion regarding the charge distribution. The original poster indicates they may have made an error in their calculations and expresses a willingness to return with further questions.
There is a noted ambiguity regarding the charge distribution of the ball, as the term "hollow" is questioned by participants. The original poster's approach to solving the problem involves multiple steps that require careful consideration of the relationships between electric field, potential, and energy.
cherrios
I've been having some trouble with this problem: A hollow ball that has radius=X, has uniform volume charge density of [tex]\rho[/tex].
1) Gauss's Law->Find electric field at .1X and 3X from the center
2)What is electric potential at .1X and 3X from center?
3) Find electric potential energy of charge q, with mass = m, when it is released 3X from center of the hollow ball. When it hits the ball, what is its speed?
For 3, would I have to equate electric potential energy to kinetic energy, and then solve for velocity?
Any tips would be much appreciated!
How does the ball have a uniform volume charge density if it's hollow? I find that confusing, I think it's meant to be a solid sphere of charge.
Your method for #3 should work fine, did you do the other two okay?
oh sorry, it's filled with uniform volume charge
1) Generally, when you need to find an electric field use Gauss' Law. The trick here is in the answer to the question, how much charge is inside your Gaussian surface? In this case, the charge distribution in uniform, so just integrate over the volume of the surface: [tex]q_{in} = \int_0^r \rho r^2 sin \theta dr d \theta d\phi = \rho * (4/3) \pi r^3[/tex], where r is the radius of your (hopefully spherical!) Gaussian surface. Now apply Gauss' Law. For the outside calculation remember that the object's radius ends at r = X. So we have a total charge [tex]Q = \rho * (4/3) \pi X^3[/tex].
2) Recall the relationship between the Electric Field and the Electric Potential. Now, since E is spherically symmetric, the E and V are related by a simple derivative of r.
3) Your method sounds like a plan to me. Unless you really WANT to find the force on the ball, use F = ma, then use the uniform linear acceleration equations. I'd rather use your method. :biggrin:
-Dan
Thank guys! I think I should be fine for now; I believe I had an integration error. I might have some questions later... but thanks again!
