Electric Field of Concentric Cylinders: r = 4.0 and 7.1 cm
The discussion revolves around calculating the electric field generated by two long, charged, concentric cylinders with specified radii and charge densities. The original poster expresses confusion about applying Gauss's law to find the electric field at specific points between and outside the cylinders.
  • Participants discuss the method for calculating the electric field for each cylinder individually and how to combine their effects. Questions arise regarding the relevance of the outer cylinder's charge when calculating the field at a point inside it.
Some participants have provided guidance on considering the contributions of both cylinders to the electric field at different points. There is an acknowledgment of the need to clarify which charges to include based on the location of the Gaussian surface.
The original poster mentions uncertainty about using Gauss's law and the implications of the charge distribution on the electric field at specified distances from the cylinders.
tbomber
Two long, charged, concentric cylinders have radii of 3.0 and 6.0 cm. The charge per unit length is 4.8 10- 6 C/m on the inner cylinder and -8.0 10-6 C/m on the outer cylinder. Find the electric field at
(a) r = 4.0 cm and
(b) r = 7.1 cm
I know how to find the electric field for each individual cylinder AT 3 and 6 cm... using this equation:
E (electric field) = Q (total charge) / (2*pi*radius*(Q/lambda)*epsilon0)
but i haven't a clue as to how to find the electric field when you include another charged surface using gauss's law...
any help would be much appreciated - as you can see I'm pretty lost.
some equations i know that may or may not help:
Lambda (sp?... linear charge density) = Q / L where Q is the total charge of the surface and L is the length of the gaussian surface
E*A = q/e0 where e0 = 8.85E-12 and q is the charge within the gaussian surface... and A is the surface area of the cylinder (not including the two circles on either end).
thanks
If you know how to find the electric field for one cylinder you can find it for both. Just include the charge from both cylinders in your Q.
And remember that the charge due to the outside cylinder does not factor into the r=4 cm calculation because you are "inside of the outside" cylinder.
-Dan
-Dan
so does that mean for A and B I'm only finding the electric field for the inside and outside cylinders, respectively?
In part (b) your Gaussian surface encloses both the inner and outer cylinders, so you need to include the charge for both. The electric field you calculate will be the electric field due to both cylinders.
  • · Replies 16 ·
  • · Replies 17 ·
