Proof using the Axioms of Addition and Multiplication
The discussion revolves around proving two statements involving the Axioms of Addition and Multiplication: 1. (-x)y = -(xy) and 2. (-x)(-y) = (xy). Participants are exploring the application of these axioms in the context of algebraic proofs.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the validity of expressing (-x) as (-1)(x) and the implications of this for the proofs. Some suggest proving this relationship first to simplify the process. Others explore the use of distributive and associative properties in their reasoning.
There is an active exchange of ideas regarding the proofs, with some participants providing guidance on how to justify each step using the axioms. Multiple interpretations of the proofs are being explored, and while no consensus has been reached, productive directions are being discussed.
Participants note the importance of justifying each equality in their proofs according to the axioms. There is also a mention of a separate proving question related to inequalities, which raises questions about the validity of the statement under certain conditions.
rad0786
So does everybody know the Axioms of Addition and Multiplication?
They are too long to type, but they are listed:
A1, A2, A3, A4, A5, M1, M2, M3, M4, M5 and the distributive law, DL.
anyways, I want to prove:
1. (-x)y = -(xy) and 2. (-x)(-y) = (xy) using ONLY the axioms of additon and multiplication.
Can somebody please help start me off, I've spent an hour on this and am getting now where
1. seems quite elementry to me.
(-x)y = (-1)(x)y by M4
(-x)y = (-1)(xy) by M3
(-x)y = -(xy) by M3 again
how does that sound?
Hmm.. I didn't know that (-x)=(-1)x was an axiom.
You should prove that one, and all your troubles vanish.
Well, (-x)y + xy = (-x + x)y = ...
I don't know what you call M1,2,3,4, etc but here's how I'd do it:
1° Prove that -x = (-1)(x)
It follows that
2° (-x)y = [(-1)(x)]y = (-1)[(x)(y)] (associativity) = -(xy) (by 1° again)
edit: I like honestrose's way better, but it's good to prove once and for all that -x = (-1)(x).
It follows that
Prove that -x = (-1)(x) : That is a theorem in the textbook, and the proof is their with it.
x + (-1)x = x + x(-1)by M2
=x1 + x(-1) by M4
x[1+(-1)]
x0
about honestrose's way,(-x)y + xy = (-x + x)y = ... (0)y = 0. Is this what he was trying to show as the proof?
(-x)y + xy = (-x + x)y (distributivity) = (0)y = 0. Hence (-x)y is the additive inverse of xy, which we note -(xy).
Right, and if a + b = 0, then b = ?
I'm a she, by the bye. :smile:
if a + b = 0 then b = -a
So if (xy) + (-x)y = 0, then (-x)y = ?
What do you have for (2)?
if (xy) + (-x)y = 0, then (-x)y = -(xy) as required.
For (2), i did it a similar way
2. Prove that (-x)(-y) = (xy) using only the axioms...
(-x)(-y) - (xy) = (-x + x)(-y) = 0(-y) = 0
thus, (-x)(-y) - (xy) = 0
therefore, (-x)(-y) = (xy)
how does that sound!? i have a feeling its good!
The general idea is good, and there is nothing you've written that is false.
But it's not detailed enough. You have to justify each and everyone of your = signs by a statement such as "by definition of ..." or "by axiom ..." or "according to theorem ..." or "by the result found in (1)". That's the whole point of proving using the axioms.
that you quasar987, In my answer, I would write "by M1, by M2, by A4... etc" (refering to the specific axiom.)
I came across another Proving question in the book, (in the same section as the axiom one.)
Prove: If [itex]x \geq 0[/itex] and [itex]x \leq \varepsilon[/itex] for all [itex]\varepsilon > 0[/itex] then [itex]x = 0[/itex]
Firstly, I decided to write it up more mathematically.
Prove: If [itex]0 \leq x \leq \varepsilon[/itex] for all [itex]\varepsilon > 0[/itex] then [itex]x = 0[/itex]
Now, this statement dosn't even look true to me. Suppose x = 9 and [itex]\varepsilon = 11[/itex], then dosn't the statement hold? But since it says Prove, ill just accept the fact that its true.
So is it possible to prove this using ONLY the axioms? i took the contrapositive and that didnt help
The statement is that if [itex]0\leq x \leq \epsilon[/itex] FOR ALL [itex]\epsilon>0[/itex]. So if you say x =9, while it is true for e = 11, it is not true for e = 8, hence it is not true for all e>0.
Try proof by contradiction. Suppose x is not zero. Can you find a number epsilon smaller than x?
