Can Spanning Subsets X and Y in Vector Space V Share No Common Vector?
  • Thread starter Thread starter stunner5000pt
    Homework Subspace
The discussion centers on the question of whether nonempty subsets X and Y of a vector space V, where span X = span Y = V, must share a common vector. Participants assert that it is possible for X and Y to have no common vectors, providing counterexamples such as X = {1} and Y = {-1} in the field of real numbers. The use of bases, such as B and 2B, further illustrates that the absence of a shared vector can occur under specific conditions. The conclusion is that while span equality holds, commonality of vectors is not guaranteed.
  • Understanding of vector spaces and their properties
  • Knowledge of linear combinations and spans
  • Familiarity with the concept of bases in vector spaces
  • Basic understanding of fields and rings in mathematics
  • Study the properties of vector spaces over different fields, including finite fields
  • Explore the concept of linear independence and its implications for vector subsets
  • Learn about counterexamples in linear algebra to solidify understanding of span and common vectors
  • Investigate the implications of scalar multiplication in vector spaces
Mathematicians, students studying linear algebra, and anyone interested in the properties of vector spaces and their subsets.
stunner5000pt
If X and Y are nonempty subsets of vector space V such taht span X = span Y = V , must there be a vector common to both X and Y? Justify.
my intuition thinks there need not be one, but i can be wrong!
to go about proving it is where the fun starts!
[tex]a_{1} x_{1} + a_{2} x_{2} + ... + a_{n} x_{n} = b_{1} y_{1} + ... + b_{n} y_{n} = V[/tex]
suppose X contaiend only one vector then ax = by. That seems to say taht one is a scalar multiple of the other
suppose X contaiend two vectors then
[tex]a_{1} x_{1} + a_{2} x_{2} = b_{1} y_{1} + b_{2} y_{2} = V[/tex]
here that means the resultant of the first addition yields the resultant of the second addition. However it doesn't mean that X = Y since ai is not bi for all i.
So there need not be any common vector
is this right? Can you help with formalizing it?
Thank you!
Maybe I got it wrong.
Let B be a basis for V. Then take X=B, Y=2B as a counter example.
Did I miss something?
*If you're not over R, replace 2 by any a!=0.
Is there a fixed field you're working over, or must this work for any field, or more generally, over any ring? When the field is F = {0, 1}, then there is a vector space over F such that if Span(X) = Span(Y) = V, then Y and X share a vector, and that is when V = F. In general, if F is any field, then there is a vector space such that if X and Y are nonempty, and span(X) = Span(Y) = V, then X and Y share a vector, and that is when V = {0}. However, there are fields and vectors spaces over them such that Span(X) = Span(Y) = V, but X and Y share no common vector. To formally prove this, you just need a counter-example: V = F = R, X = {1}, Y = {-1}.
