An effort to solve Zeno's motion Paradoxes
  • Thread starter Thread starter N.N.
    Motion
The discussion revolves around Zeno's motion paradoxes, exploring various interpretations and resolutions of these philosophical puzzles. Participants examine the implications of discrete versus continuous models of space and time, and how these assumptions affect the understanding of Zeno's arguments.
  • Some participants propose substituting pixel-like points for geometric points to resolve Zeno's paradoxes, suggesting that movement occurs as "jumps."
  • Others argue that Zeno's paradoxes are not true paradoxes, asserting that Zeno was simply mistaken about the nature of motion and infinity.
  • A participant contends that Zeno understood the infinite series but believed it would take an infinite amount of time to complete the addition, thus maintaining that the paradox stands unless spacetime is assumed to be continuous.
  • Another viewpoint suggests that Zeno's assumptions about space being infinitely divisible and time being atomic lead to contradictions, particularly when considering the crossing of segments in motion.
  • One participant outlines four famous paradoxes by Zeno, emphasizing that each generates different puzzles based on the discrete or continuous nature of space and time.
  • Some participants challenge the categorization of the paradoxes, arguing that certain assumptions lead to illogical rather than paradoxical conclusions.
Participants express multiple competing views regarding the nature of Zeno's paradoxes and whether they can be resolved through different assumptions about space and time. The discussion remains unresolved, with no consensus on the validity of the paradoxes or the proposed solutions.
Participants highlight the dependence on definitions of space and time, and the unresolved nature of assumptions regarding their continuity or discreteness. The discussion reflects a variety of interpretations and challenges to Zeno's original arguments.
N.N.
As titled.
Zeno's paradoxes are easily solved if you substitute pixel-like points for geometric points... All you do is say that instead of being an infinite number of sizeless points in the universe there is a finite number of points with finite size... I've got a few theories based on this that also integrate general and special relativity, but I needn't go into detail on this stuff right now. Heh, I didn't read the whole article but isn't that essentially what it says? That all movement occurs as "jumps"? :)
There is no paradox, Zeno was simply wrong. The only "paradox" is that there are those who don't know where Zeno went wrong.
(I.e. that the sum of the infinite series 1/2 + 1/4 + 1/8 ... = 1)
I think that Zeno was well aware that the infinite series 1/2 + 1/4 + 1/8 ... = 1. It doesn't solve the paradox because it would take an infinite time to do the addition.
His paradox stands (imho) unless one assumes that spacetime is a continuum, in which case there is no paradox.
Right.
I think Zeno is assuming space is infinitely divisible here, and time is atomic. So the length of time it takes to do something is the sum of the time-atoms consumed. But since space is continuous, you can form the segments 1/2, 1/4, 1/8, ... which form an infinite set, and if crossing each segment takes one irreducible atom of time, there will be an infinite number of them, which is absurd.
As I've posted before, I think Zeno was "running the cases" of time and space separately being discrete or continuous. His program is obscure to us because our only source for his paradoxes is Aristotle, who scrambled them some.
Originally posted by selfAdjoint
Right.
But if spacetime is continuous there is no 'irreducible atom of time'.
It is best to consider together four famous paradoxes by Zeno of Elia. Someone later discovered that each one generates a different puzzle, depending on whether space is taken as discrete or continuous and time is taken as discrete or continuous.
space discrete; time discrete ->
stadion paradox: A, B and C are blocks of space, like train carriages. Block A moves rightward one unit of space per unit of time with respect to B. Block C moves leftward one unit of space per unit of time with respect to B. The speeds of A and C with respect to B are maximal values, since nothing can move faster than one unit of space per unit of time (otherwise, a minimum unit of time can be subdivided). But A moves rightward two units of space per unit time with respect to C. C moves leftward two units of space per unit time with respect to A. That is paradoxical.
space discrete; time continuous ->
arrow paradox: An arrow goes from position A to position B. Therefore it has a discrete set of space positions between A and B. For every moment of time that the arrow is in transit, the arrow is at one position. So at every moment of time the arrow is stationary. But the arrow moves from A to B. That is paradoxical.
space continuous; time discrete ->
dichotomy paradox: To move from point A to point B it is necessary to reach the halfway point between A and B at some time. To move from position A to the halfway point to B it is necessary to reach the quarterway point between A and B at some time. Each arrival requirement has an additional arrival requirement of half the previous distance. But there are only a discrete sequence of times. So, a mover must be at two or more positions at some minimal unit of time. That is paradoxical.
space continuous; time continuous ->
Achilles paradox: A tortoise runs a race with Achilles, who can run ten times as fast as the tortoise. But the tortoise gets a handicap of some distance ahead of Achilles for the starting point. Both runners start at the same moment of time. When Achilles arrives at the starting point of the tortoise, the tortoise has arrived at a point one tenth of that distance. When Achilles has run that distance, then the tortoise has arrived one tenth of the one tenth distance ahead of Achilles. No matter how long Achilles overtakes the former positions of the tortoise, the tortoise is still ahead of him. So faster Achilles never does overtake the tortoise. That is paradoxical.
Note that "paradox" doesn't necessarily mean "impossible". "Paradox" means hard to accept.
Nice post. A few comments.
One unit of space per one unit of time is also the slowest speed that one can go (without stopping), a paradox in itself.
Don't agree with this. It assumes the existence of 'moments,' which contradicts the premise. I feel the arrow paradox is in the 'discrete space and discrete time' category. They have to be same at all times, either both discrete or neither, since they are so inextricably bound up in each other. (If there are no 'moments' in time then there are no precise positions in space. Therefore to assert otherwise is illogical rather than paradoxical).
But there is no point between A and B. As above this is illogical rather than paradoxical (as written).
This is the paradox, but it is not a paradox because it assumes space and time are continuous. If you think about it assumes that they are not, and that's why it's a paradox. (If spacetime is continuous then there are no precise positions or moments and there is no paradox). The Achilles paradox is really a reduction ad absurdamof the argument for quantised spacetime.
Note that "paradox" doesn't necessarily mean "impossible". "Paradox" means hard to accept. [/B]
I'm not sure I agree with that, since we assume that logical contradictions are impossible in physical reality, but no matter.
arrow paradox:
Canute: It assumes the existence of 'moments,' which contradicts the premise.
If 'moment' means a duration, then I will reject the use of that word. Maybe "instant" would be acceptable.
So:
"For every instant of time that the arrow is in transit, the arrow is at one position. So at every instant of time the arrow is stationary."
Canute: I feel the arrow paradox is in the 'discrete space and discrete time' category.
The paradox is more interesting in the discrete-space/continuous-time setting. Otherwise, no definite statement about the motion within one single minimum duration of time will be possible. But if there are two instances of time within one space position, that is prima facie a stationary state.
It takes the more complicated stadion situation to handle the discrete-space/discrete-time case.
Canute: They have to be same at all times, either both discrete or neither, since they are so inextricably bound up in each other.
I can't say I understand why (,or what follows).
dichotomy paradox:
Canute: But there is no point between A and B.
With space supposed continuous, there are plenty of points between A and B. A geometrical construction can locate the midpoint of any line segment, however small.
I would have expected a complaint that my conclusion to dichotomy is not the usual conclusion, and I would have to agree. The usual conclusion of dichotomy is that the mover can't get started. This would require the assumption of continuous-time. I changed it to match the discrete-time assumption. I consider this case the weakest.
Achilles paradox:
Canute: If you think about it assumes that they are not [continuous], and that's why it's a paradox.
Reckoning the time interval for Achilles to attain the last point of the tortoise requires continuous-space, and itself requires a continuous-time value to keep the recurrence going.
The real answer to Achilles is that it deliberately considers only time-instances and space-points in which Achilles is behind the tortoise, and never considers any time-instances or space-points when Achilles isn't behind the tortoise. It is able to trap us in that range because of continuity.
quartodeciman: Note that "paradox" doesn't necessarily mean "impossible". "Paradox" means hard to accept.
I like this, because "paradox" is antonymous to "orthodox". The latter means "straight opinion", so the former means "un-straight opinion". If needed, one can use "antinomy", which means "counter rule".
arrow paradox:
I don't think it matters what you call them. (If you do a search on Peter Lynds you'll find a couple of physics papers in which he argues 'instants' are an impossibility).
It seems to me that to say that time is continuous is to say that there are no instants, that is you cannot 'reify' instants. I've argued this elsewhere with little success, however it seems obvious. Perhaps I'm missing something.
If time is continuous then all 'instants' are of arbitrary duration and position in time. If space is continuous then all positions are arbitrary, and reduce to mathematical points. Is there any argument against this? I can't find one.
I like this, because "paradox" is antonymous to "orthodox". The latter means "straight opinion", so the former means "un-straight opinion". If needed, one can use "antinomy", which means "counter rule". [/B]
I see your point. But a paradox is a self-contradiction. If it models reality then unless reality itself is self-contradictory then the situation it describes is impossible, and there must be something wrong with the premisses underlying the paradox.
A lot of times, a paradox is merely someone making an unwarranted assumption which leads to a contradiction.
I can't think of any exceptions to this. Don't all paradoxes arise from faulty assumptions?
There are only two points in a race. From point A to point B. You could skew the race by saying there is a halfway point a runner must reach before point B is arrived at. That is the equivalent of running a completely different race, but still no different than running from point A to point B. The point here is that there is no halfway point in any given distance you so choose to move in. If the distance between point A and B is infinitely devisible - No halfway point is possible witout changing to to a finite system. Hence Zenos paradox gets lost in an infinite sea through contradiction ,,,,, over and over again. By placing a finite system over an infinitely devisible one - We contradict the whole premise of point A to point B.
All that is needed here is to allow the race to take place by which point (AB) becomes the whole point of the race. Point A is the runner with a destiny for point B. They meet to complete the (AB) point of the race. Don't excuse the puns - They are intended.
Even if this is incorrect, they are certainly interesting things to discuss.
This assumes that time and space are granular (not just discrete), and that motion is continuous, a combination that only works if time consists of one instant, and space consists of one point.
First off an arrow has positive size, so there are many positions that it can occupy simultaneously, so it's not entirely clear that the position of the arrow is well defined.
Let's say, that we have an idealized arrow, and that the arrow's position is indeed always well-defined, and that space is granular and that time is continuous. Then you do have a series of intervals in which the arrow is at rest. However, the velocity of the arrow could still be a hidden variable that is not apparent during that interval. This leads to a qm-like situation where we know where it is, but we only have bounds on it's velocity.
Once again, this assumes that time is granular so that there is a minimum time interval. This particular paradox assumes that the location of a moving object can be well-defined in a granular time system.
Achilles paradox: A tortoise runs a race weith Achilles, who can run ten times as fast as the tortoise. But the tortoise gets a handicap of some distance ahead of Achilles for the starting point. Both runners start at the same moment of time. When Achilles arrives at the starting point of the tortoise, the tortoise has arrived at a point one tenth of that distance. When Achilles has run that distance, then the tortoise has arrived one tenth of the one tenth distance ahead of Achilles. No matter how long Achilles overtakes the former positions of the tortoise, the tortoise is still ahead of him. So faster Achilles never does overtake the tortoise. That is paradoxical.
This last one is a red herring. "Never" refers to the inability to complete the sum, not to the amount of time being infinite.
Forgive me.
I use "paradox" in the sense of
Bolzano, Bernhard. Paradoxes of the Infinite.
from the early nineteenth century. The word was used earler than that by Galileo in discussing infinite collections. For example, a small circle and a large circle with a common center have the same number of points on them, though one is obviously longer than the other. The sense that "paradox" means exactly a logically-contradictory or incoherent situation is a more recent usage. I suspect the paradoxes of Zeno are resolvable by acceptance of difficult principles, rather than by their rejection as being nothing but antinomies.
No one has to accept this particular rundown of the Zeno paradoxes. It was a later assessment. the paradoxes stand on their own and it is up to us what lessons can be learned from them. Most of us will not accept the eliatic conclusion intended by Zeno and his master, Parmenides, namely: all is one and cannot be rationally separated into parts, neither spatially nor temporally, nor any other way.
It is a matter of fact that if there are two points A & B separated by one meter, and I travel at 1 meter per second, I can traverse that distance in as little as one second. Not an infinite amount of time by any standard.
Zeno was wrong, anyone can prove him wrong. d = v * t is the controlling equation. Anyone who knows that the infinite series 1/2 + 1/4 +... = 1 (as you postulate Zeno did) would understand this: Regardless of how you split the series, v is constant. Thus t = d/v and the projected time of arrival is easily determined and is finite, in accordance with everyday experience.
Only someone who is distracted by the "sleight of hand" of the infinite series concept would see a paradox. It matters not that space is assumed to be continuous or discrete, that too is a distraction.
Ah, but that's cheating. Zeno is arguing that if spacetime is quantised it is logically impossible for us to travel at one metre per second. You've just assumed that we can, and thus avoided the problem.
quartodeciman
What do you think those difficult principles are?
First, I don't agree that spacetime quantized has anything to do with being able to travel at 1 meter/second. A quantized space is traversable too. Logically, the series does not proceed to infinity.
Second, even if I did concede that, I would logically conclude that space is therefore NOT quantized as a result of experiment.
Either way, no problem. But I question whether Zeno was aware of these considerations.
"I suspect the paradoxes of Zeno are resolvable by acceptance of difficult principles, rather than by their rejection as being nothing but antinomies."
Canute, I was hoping you wouldn't ask about this. I will just watch for a while and see what (if anything) dawns on me.
Maybe I should have said:
"I suspect the paradoxes of Zeno are resolvable by acceptance of deeper principles, rather than by their rejection as being nothing but antinomies."
Fair enough. I feel that 'difficult principle' is that spacetime is not quantised. I admit that it's quite hard to make sense of the idea, since it has metaphysical consequences as well as scientific ones. But in its favour that's just what we would expect if it were really true.
Here's an attempted modernisation of Zeno.
Zeno Restated.
Let us assume that spacetime is quantised.
Continuous motion implies that a fundamental quanta of matter is able to move from one point in spacetime to an adjacent one.
Take fundamental particle A at point P1. Let us say that A is an athlete amongst particles. How fast can it go?
Let’s separate time and space. In space A is a fundamental particle at a precise point in space. If it is to move to another position non-instantaneously then it must take time to do so. But how little time?
Let’s say that there are three positions, P1, P2, P3 in a straight line in space, three points on a piece of paper. These are three adjacent fundamental quanta of space (points).
A is at P1. If it wishes to get as fast as possible to P3 then it must take at least two instants. This is because for A to get from P1 to P3 in one instant requires instantaneous travel. If instantaneous travel is possible at the quantum level then all bets are off, we might as well put P1 and P3 on opposite sides of the universe. This means that A can move no faster then one change of point per instant, and only to a spatially adjacent one.
How slow can A go?. If it is to reach P2 at all then it must do so in no less than an instant. If it went slower than this it would have to stay at P1 forever. This means that A cannot go slower then one change of point per instant, and always to an adjacent one.
Thus in a world in which spacetime is quantised everything must move at the same speed, and athletes cannot catch tortoises.
What's wrong here?
canute:
what if the A exists at all positions P1 through Px and our observation, at Px, is a matter of perception. It has always beem there. Potentially or in reality? i dunno. it may simply appear where it is needed. to be seen? acted upon? collapsed?
TIME does not exist; it is a human necessity to percieve our physical framework and understand the experience. once i remove the limitations of time-space i can understand quantum theory.
IMHO, accepting that all probabilities are valid, i can then focus on one instant and/or an entire thread of probablities. they are linked so that my consciousness can absorb the experience and expand its awareness; the universe expands. again, we (humans) can only observe this instant (present), our total being may be in an infinite number of worlds absorbing their wonders. much like(but on a grander scale) our bodies having one foot in warm water, one foot on ice and our genitals--- errrr, you get the message. needless to say i haven't had time to polish this analogy.
peace,
Travel in a quantized space-time system proceeds by jumps, with 0 duration for each jump. This would naturally be graphed by a step function with vertical lift.
So, your A could stay at P1 for 1, 2, 3 or more time units, then jump to the next space unit and stay there for the same number of time unit counts, and so on. The overall rate of progress from P1 to P2 and on can be made sequentially smaller, yet remain greater than 0.
This also offers a clue, I think, to resolving the arrow paradox in the continuous-time, discrete-space system. The positions sampled at different time instances within one space unit are equal, but that is exactly what we expect for a step function. Samples within an interval of the independent variable do not even try to approximate the jump that actually occurs at the end of the interval. So they are not representatives of the overall motion of an arrow (of length one space unit, if you want) at all.
(* is just for spacing)
s ************ ---|
p ********* ---|
a ****** ---|
c *** ---|
e ---|
time ->
On the other hand, there is no subdivision of a quantized time unit, so a maximum speed is automatically defined for anything that is confined to occupying a single space unit at a time. Does this perhaps define the limiting speed c? I read that Loop Quantum Gravity theory attempts to structure space and time units, using the Planck length and Planck time as units. It appears that the ratio of PL to PT is c. I don't know whether that theory exploits this.
http://scienceworld.wolfram.com/physics/PlanckLength.html
http://scienceworld.wolfram.com/physics/PlanckTime.html
Olde drunk
That seems to be a possibility. It does at least solve the problem.
Quartodeciman
I specified continuous motion above, so your solution doesn't work. However maybe motion isn't continuous, as you suggest. It seems an insane idea to me but then so do quite a number of current theories of motion. Do you really think that particles proceed in stops and starts? Doesn't it contradict the known laws of momentum and energy conservation?
I didn't quite understand your example.
I agree that c is connected with all this. It's interesting that by the the other view allowed by Galilean relativity photons are are actually at rest, (since time does not pass for a photon). Perhaps c is a limit because at c one is stationary, and you can't go slower than that, if you see what I mean.
Canute:
I'm completely stuck over continuous motion in a discrete space (and/or time) system. Continuity demands that every intermediate value be assumed at some time within. But we otherwise tend to think motion in terms of FROM and TO times. So I stick with discontinuous motion (at the jump instances) and just shut my trap about it.
My example using Planck length and Planck time just sets smallest discrete intervals of distance and duration to values whose ratio just happens to be c. This presumes that jumps more than one space unit are forbidden. Then the maximum average speed looks like c. If jumps of magnitude greater than to an adjoining space unit are allowed, then a higher speed would be attainable. I repeat that I don't know whether this is theoretically significant.
About photons being at rest:
Everybody is at rest in Special Relativity as long as they are inertial and use their own proper measuring standards for reference. So an observer that trips the light fantastic (rides constantly within a photon stream) still has a proper space and time. What is missing is the ability to exchange light signals between this observer and a homie observer (that stays behind) after departure and separation. That is because any light signal must not exceed c. But the speed of the other observer for either observer is c, so no catchup can occur. This renders the relationship of the Lorentz Transformation impossible to apply.
Am I right that in your example (using P-length and P-time) for an object to go at any average speed slower than c entails that it pauses between positions?
I've had a few conversations about Zeno and quite a few people seem to be happy with the notion of intermittent motion. I can't see how it makes sense, but then the world is strange place.
I think I get your last para. Doesn't SR imply that there is no absolute reference for motion, and that therefore there is no absolute backdrop for it, i.e. that spacetime is a concept and not a thing?
Canute:
I reckon that a postulation of a minimum spatial quantum means that all one can say is that something is AT some quantum position, so it is true that it stays AT one place until it DOESN'T(!)
More on SR:
It interests me that Einstein's two immediate predecessors in the development of the theory are Lorentz, a true physical theorist, and Poincaré, a true mathematical theorist. For Lorentz, it was physical dynamics that determined the Lorentz transformations and for Poincaré it was the underlying group structure that predominated. Einstein switched to kinematics and a special postulate, lightspeed invariance. As such, one might consider Einstein as presenting an intermediate position on the Lorentz transformation question. But he remained a pure physical theorist for several years, and there was much confusion about any distinction between his position and that of Lorentz. People talked about a Lorentz-Einstein theory back then. Einstein only changed his framework when he got hard to work on a generalization that would include gravitation. Then local Lorentz and general invariances took over his approach to a new theory.
Let's roll back to SR. For pre-relativity theory, it is rest (zero) speed that is uniquely central and neutral; for relativity theory, it is speed c that is uniquely central and neutral. Rest speed is just a particular choice of reference frame and not unique at all.
I'm afraid I have stretched this topic thread too far from its original point, and I apologize for that.
Canute:
I agree.(edit - I mean I agree that's a good way of putting it. You have a knack of putting it straightforwardly).
I'm afraid I have stretched this topic thread too far from its original point, and I apologize for that. [/B]
Still the same subject though.
Quarto
In case you're interested try running Zeno's race with two fundamental particles hopping across quanta of spacetime like stepping stones.
Before you know it you get indeterminate positions and differences in relative lengths due to relative velocities. Strangely familiar stuff.
  • · Replies 46 ·
9K
