Solve the Riddle: Old Man Walks Across Bridge With 3 Bars
  • Context: Undergrad
  • Thread starter Thread starter flirt
    Riddle
The discussion revolves around a riddle involving an old man who must cross a bridge while carrying three gold bars, each weighing 1 kg, without exceeding the weight limit of 80 kg. Participants explore various strategies and the underlying physics of the situation, including the implications of juggling the bars and alternative methods of transport.
  • One participant suggests that the old man could juggle the bars, questioning the physics of weight distribution and forces exerted on the bridge during the act of juggling.
  • Another participant challenges the juggling idea, stating that the forces involved in accelerating and decelerating the bars would exceed the weight limit, especially if the upward g-force is greater than 1 g.
  • A different approach is proposed where the man could throw two bars up and catch them before they fall, although this contradicts the rule against throwing the bars.
  • One participant suggests laying down the bars on the bridge in sequence, but another counters that this would still result in the same total weight on the bridge.
  • Alternative ideas include removing weight by taking off clothes or removing boards from the bridge, though these suggestions are met with skepticism regarding their feasibility.
Participants express multiple competing views on how the old man might successfully cross the bridge without exceeding the weight limit. There is no consensus on a definitive solution, and various strategies are debated without resolution.
Participants highlight the importance of understanding the forces involved in juggling and the implications of weight distribution, but the discussion remains theoretical and speculative without definitive conclusions.
flirt
This one may take a while to get to the physics but is a good challenge for a mate with a sharp mind. My friends would like to know the answer and the physics behind it, so any answers would be appreciated.
There was an OLD man out for a walk one afternoon and he decided to walk across a long wooden bridge that leads to a mine on the other side, before he walkes across the bridge he noticed a sign, which stated “this bridge will collapse if anything heavier that 80kg’s is placed on it”. After reading this the old man resumes his walk over the bridge knowing full well he only weighs 78 kg and is safe from it collapsing. He reaches the other side and goes in the mine, a min. later he walk’s out with 3 gold bars each weighing 1kg. The man then resumes on back to the bridge. Once he reaches the bridge he finds himself with a dilemma. He has to cross the bridge with all 3 bars otherwise by the time he gets back for the last bar he fears someone would of taken it, but if he crosses the bridge with all three bars this would then make his weight more than 80kgs (81kg) and the bridge would collapse. How does he do it?
*you can not swim
*you can not fly
*you can not throw the bars
*HE MUST WALK ACROSS THE BRIDGE
*the bars must be in a close vicinity to him at all time (1-2m at the most away from him and he must always be holding that majority of the bars {e.g. 2bars})
The answer you supposable should come up with is …. “He juggles them”. This is were the dilemma comes in, each time the man throws the bar up in the air is he not pushing down on the bridge with a greater weight than the brick itself (e.g. velocity mass force all play a role) and let's also assume he catches the brick with the other hand, wouldn’t there be a greater force exerted by catching the brick than holding it at stand still because of the gain in velocity from gravity on its fall.
These are all theoretical but the speed at which he tosses the bricks into the air would have a factor in the force pushing down.
Try and figure it out and remember “for every action there is a greater or equal reaction”
What's that? Newton's 4th law? :wink:
(Assuming you are talking about action/reaction forces ala Newton's 3rd law, then "action" and "reaction" are exactly equal and opposite. These forces are better called "3rd law pairs" than "action/reaction".)
*you can not swim
*you can not fly
Ok, weight is essentially mass * net-g force. The man deccelerates and accelerates the gold bars everytime it is passes. The energy he puts into them goes back as energy he gets back. If the gold bars experience an upward g-force greater than 1 g, then the technique is useless when you have two gold bars in the hand at the same time. If the gold bars experience an upward g-force greater than 2 g's, then it is useless to juggle at all.
In short, flirt, you are right that juggling wouldn't help because of the force of accelerating/decelerating the gold bars.
What if he threw two up, then caught them before they started falling down, after throwing the last one up, and repeating?
He can't thorw them.
What if he two lays one bar on one part of the birdge then he carries the other one then he lays that one down and goes gets the other one and he keeps doing until he gets across.
What about taking off 1 kg of clothes?
Or what about removing 1 kg of boards off the bridge?
kmarnas86 you thinking out of that square arnt you, that didnt even cross my mind, well done
scott1 even if he could do that the bridge would still have 3 kg more weight on it and it would be the same as the guy holding them, therefore break bridge
  • · Replies 18 ·
11K
  • · Replies 125 ·
21K
  • · Replies 66 ·
16K
  • · Replies 25 ·
9K
