| Thread Closed |
Brain Teaser #72 |
Share Thread | Thread Tools |
| Dec18-03, 01:02 AM | #1 |
Admin
Brain Teaser #72
Enter through one, exit through two, then enter through two, exit through one.
What is being enter/exited? |
| Dec18-03, 01:26 AM | #2 |
| Dec18-03, 03:38 AM | #3 |
[o)]
1 and 2 2 and 1 |
| Dec18-03, 03:53 AM | #4 |
Brain Teaser #72
A lumped element in a alternative current circuit :)
1 and 2 are its "starts" and "ends", which are equivalent in an alternative current circuit... |
| Dec18-03, 04:52 AM | #5 |
Your hands. Putting on and then taking off a T shirt.
Oops,,, I meant to say the shirt was he thingy bieng entered then exited. Probably a beter thing would by the same relation on your pants considering feet? But let's not go there, these mofos stink![g)] |
| Dec18-03, 06:02 AM | #6 |
my answer is air. air enter in our mouth (which is one) and can exit through our nose (which has two holes [sorry for the bad terminology] and opposite as well.
| Dec18-03, 07:46 AM | #8 |
Recognitions:
A Mach-Zender interferometer. I don't know if it is the answer you're looking for, but it fits perfectly.
Njorl |
| Dec18-03, 08:48 AM | #9 |
What about elevator? Enter "though" first floor, exit through "second", then vice-versa and go home... eh? [;)]
also could be a train: enter at station A through the left door, exit at station B through right door, then from B to A in a different manner... however, a capacitor in AC circuit fits more... |
| Dec18-03, 09:19 AM | #10 |
Any one of the 4 areas created by two non-paralell infinite lines in R^2. You can cross through either at the intersection - (through 2), or not: (through 1).
| Dec18-03, 01:08 PM | #11 |
| Dec18-03, 01:41 PM | #12 |
Recognitions:
In a Mach-Zehnder (I spelled it wrong initially) interferometer, a single beam of light enters, is split into two beams which travel identical pathlengths through an electro-optically active material, such as lithium niobate or gallium arsenide, then recombined. While the beams are seperate, one of them is subject to a slight perturbation. This usually takes the form of an applied electric field. The index of refraction that one beam experiences is slightly alterred, making it experience a slightly different path length. With the correct bias, you can induce a pi/2 phase shift in one arm of the interferrometer. This allows you to modulate the throughput signal from 0-100% at very high speeds (>100 GHz).
Edit - Just wanted to add, I worked on a rib-waveguide version of this. When I read the riddle, I thought of it immediately. We made it by combining elements we already designed - a 1 to 2 splitter and a 2 to 1 combiner - one entrance two exits, two entrances one exit. Njorl |
| Dec18-03, 01:53 PM | #13 |
dare i to argue that the first beam of light is different from the end product when the two seperated beam combined?
| Dec18-03, 02:02 PM | #14 |
Recognitions:
I'm sure there is a better answer. I just can't think of it because I have my MZI on the brain. Njorl |
| Dec18-03, 02:11 PM | #15 |
| Dec18-03, 05:14 PM | #16 |
A heart?
Enter through one right atrium, exit through two pulmonary arteries, enter through two pulmonary veins, exit through one aorta? (It would work better if I could say, enter through one vena cava, but there are 2 of those.) |
| Dec18-03, 11:32 PM | #17 |
don't think is the blood in the heart, since blood from the right atrium, exit throught 1 pulmonary trunk, then enter 2 pulmonary arteries.
i was thinking about excretory system too, but too lazy.... the question is kinda ambiguous. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Brain Teaser #72
| Brain Teaser #56 | Brain Teasers | 2 | ||
| Brain Teaser #45 | Brain Teasers | 3 | ||
| Brain Teaser #54 | Brain Teasers | 3 | ||
| Brain Teaser #52 | Brain Teasers | 2 | ||
| Brain Teaser #36 | Brain Teasers | 5 | ||
