Gyroscope precession - WHY? (What's the cause?)
The discussion centers around the phenomenon of gyroscope precession, specifically seeking a theoretical explanation for why a gyroscope precesses rather than simply rotating about its expected axle when in motion. Participants explore the underlying principles and mechanics involved in this behavior.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants assert that the behavior of precession follows from Newton's Laws of Motion applied to rotating systems, challenging the notion that it is merely an assumption.
  • Others propose that the conservation of angular momentum is key to understanding precession, suggesting that the final angular momentum results from the initial angular momentum plus the effect of torque over time.
  • A participant introduces a hypothetical model involving point masses on a rigid rod to illustrate the principles of precession, although the details of this model are not fully elaborated.
  • One participant expresses satisfaction with an explanation regarding the relationship between the gyroscope's rotation and its principal axis of maximum moment of inertia, but seeks further clarification on why this relationship exists.
  • Several participants engage in defining and questioning the concept of the principal axis of maximum moment of inertia, with some suggesting that the axis through the centroid may not align with this definition.
Participants do not reach a consensus on the definitions and implications of the principal axis of maximum moment of inertia, and there remains uncertainty regarding the theoretical explanations for gyroscope precession.
Discussions include varying interpretations of angular momentum and torque, as well as differing views on the definitions of principal axes, which may depend on specific contexts or assumptions not fully articulated in the thread.
panathi
«(...) a torque τ applied perpendicular to the axis of rotation, and therefore perpendicular to L, results in a motion perpendicular to both τ and L. This motion is called precession.»(http://en.wikipedia.org/wiki/Gyroscope)
Why does this happen? Assumpting this makes all further calculus very easy and we can calculate the angular speed of the precession motion without difficulty (see http://physics.nad.ru/Physics/English/gyro_txt.htm).
But WHY do we assumpt this? What's the reason why the gyroscope does not rotate over the "expected" axle, as it does when the rotor is stopped? (I do not want you to tell me about experimental facts... I think it is pretty obvious that I am seeking for a theoretical explanation)
Please answer me as soon as possible. Thanks in advance.
Stay cool!
Because the angular momentum of the gyroscope is conserved.
Draw the vector L for the initial angular momentum of the gyroscope.
Draw the vector [itex]\Delta T \tau[/itex] for the amount of angular momentum transferred to the gyroscope from a torque [itex]\tau[/itex] acting for a time [itex]\Delta T[/itex].
Observe that the final angular momentum of the gyroscope is given by the intial angular momentum plus torque*time.
First, it is not an assumption! It follows quite rigorously from Newton's Laws of Motion applied to a rotating system or rigid body. As for the "expected" behavior, it is only "expected" if you insist on thinking about it as a nonrotating system.
You can find an adequately detailed explanation here: http://en.wikipedia.org/wiki/Precession
This is easier if you analyze a simple hypothetical object such as two equal point masses attached to the ends of a massless rigid rod, that rotates around the midpoint of the rod. A long time ago, I saw a derivation that used this model, but I don't remember where.
Thank you guys :)
«The permanent axis must turn towards this line, since the body cannot continue to rotate about any line which is not a principal axis of maximum moment of inertia; that is, the permanent axis turns in a direction at right angles to that in which the torque might be expected to turn it.»
(http://en.wikipedia.org/wiki/Precession)
This piece of information clears my doubts and explains why the gyroscope makes de precession motion. But why does the body tend to rotate around a line which is a principal axis of maximum moment of inertia?
Thank you all that answered me promptly. :)
Farewell
http://www.thehowandwhy.com/Gyroscopic.html
How do you define this?
Its pretty self explanatory. Its simply the axis that yeilds the highest (most resistivity to spin) moment of inertia.
The MINIMUM moment of inertia about any axis passes through the centriod (center of mass of a uniformly dense object).
Can the axis who passes through the centriod be considered the principal axis of maximum moment of inertia? This makes no sense for me. :s Please keep helping please.
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 35 ·
