How Do Salt Solutions Affect Egg White Protein Structure?
The discussion focuses on the effects of various solutions on egg white protein structure, specifically examining weak and strong salt solutions, weak and strong acids, and bases. The experiment revealed that weak salt solutions kept protein at the bottom, while strong salt solutions caused it to rise. Strong bases denatured the protein into a thick gel, while strong acids also led to denaturation. The participant seeks clarification on how salt solutions alter protein structure, particularly regarding peptide bonds and amino acid side chains.
  • Understanding of protein structure and denaturation
  • Knowledge of peptide bonds and amino acid interactions
  • Familiarity with acid-base chemistry
  • Basic laboratory techniques for protein analysis
  • Research the role of ionic strength in protein stability
  • Explore the effects of salt concentration on protein solubility
  • Investigate the relationship between pH levels and protein denaturation
  • Learn about the impact of amino acid side chains on protein folding
This discussion is beneficial for students studying biochemistry, food science professionals, and anyone interested in protein chemistry and denaturation processes.
Jordan_
Hey, I have some homework questions and I'd appreciate some clarification.
As a class we did an experiment where we put egg white into seven different test tubes, and then introduced seven different solutions, one to each test tube. The different solutions were weak & strong salt solutions, weak base (ammonia), strong base (sodium hydroxide), weak acid (acetic acid), strong acid (hydrochloric acid), and acetone.
For the strong and weak salt solutions, nothing really happened at all, except that for the weak salt solution, the protein stayed near the bottom of the mixture and in the strong solution the protein stayed near the top. In the weak base, the protein stayed near the bottom and the top was very clear liquid. In the strong base, the protein denatured into thick white stuff. In the weak acid, the protein did not really denature as far as I saw, just stayed at the bottom of the test tube with clear liquid above it. On the strong acid, the protein again denatured. In the acetone solution, it was clear on top, denatured protein in the middle, and egg white protein on the bottom.
I am thinking the reason it denatured had something to do with peptide bonds holding amino acids together breaking and then reassembling different ways, creating the thick white gel stuff. I just don't really know how to explain this. Can you guys give me any tips on where to start looking because I'm sort of lost.
Thanks in advance.
You should look in another direction. Try to look at the effect of the side chain of the amino acid and the charge of the polypeptides on tertiary structure.
Okay, I've got most of my research done. I just need to know how does the weak and strong salt solutions alter the structure? I've seen it listed in places that it works the same way as acids and bases, but it never really goes on to explain how. I really need to know how to understand this.
Thanks in advance.
50K
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 39 ·
18K
10K
