What are the forces acting on an object sliding down a hill?
The discussion revolves around the forces acting on an object sliding down a hill at a 30-degree angle to the horizontal, specifically focusing on the calculation of the frictional force given the mass and acceleration of the object. The context involves Newton's laws of motion.
  • Participants discuss the construction of a free body diagram, the application of Newton's laws, and the resolution of forces acting on the object. Questions arise regarding the correct identification of forces, particularly the role of gravity and friction.
Participants are actively engaging with the problem, offering clarifications on the forces involved and the need to resolve components of the weight acting down the incline. Some guidance has been provided on how to approach the problem, but confusion remains regarding the interpretation of gravitational forces and the necessity of resolving certain forces.
There is a noted confusion about the distinction between gravitational force acting downward and its components along the incline. Participants are also navigating the implications of the problem setup and the assumptions that can be made based on the information provided.
sauri
homework help!
Hi! everyone I am new tp physics and I need help. We had just finished a part on Newtons 1st and 2nd laws and were given a question as follows.
An object is sliding down a hill, at an angle 30 degrees to the horizontal. The object has mass 50Kg. If the acceleration of the object is 0.6 ms^-2, what is the friction force acting on the object.
So, I first began by constructing the free body force dig. I marked the weight Mg downwards, the normal reaction R upwards, frictional force backwards and a force P forward. So firstly did I mark it correctly?
Now I know that F=ma does apply here but I am not sure about the other component. All I could come up with is
Psin30+mg = R and F= Pcos30.
I know something is wrong here but I don't know what!. Can anyone help me please?
[tex]\large F_{\text{friction}=\mu mg\cos\theta=(\tan\theta-\frac{a}{g\cos\theta})mg\cos\theta=...[/tex]
Thnks for the reply but I can't understnd the equation you have given. Could you explain the equation or is there any other way to find the friction by resolving the individual forces?
Thanks again.
Welcome to PF! Your diagram is nearly right. The gravity should be acting straight down and frictional force acting backwards parallel to the inclined plane as you say. Make sure the normal reaction force is acting upwards perpendicular to the inclined plane. However, your question does not mention an additional accelerating force so you have to assume gravity is the only force acting and therefore you don't have a force P.
You need to startby summing all the forces acting to pull the object down the hill, in this case it is only gravity, but you need to resolve the force parallel to the inclined plain. However, there is a frictional force acting to oppose the force of gravity so using Newton's law [itex]F = ma[/itex] we can say:
[tex]F_{net} = ma \Rightarrow F_{gravity} - F_{frictional} = ma[/tex]
Don't forget to resolve the force of gravity (using trig). The frictional force doesn't need resolving because it always acts parallel to the plain of motion.
Hope this helps.
O.k, I am still a bit confused because the question states that the object is sliding down the hill at an angle of 30 degrees, so shouldn't there be a gravitational force acting in that direction?. I was kinda thinking that while the weight (Mg) acted directly downwards, gravity (g) would act at an incline of 30 degerees to the horizontal. Or am I still going about it the wrong way??
That also leaves me with the resolving of the forces. Thanks for pointing put that Friction does not need to be resolved. So left with gravity I end up with R=mg+gsin30. This is according to my current diagram anyway. So is this correct?
You can resolve the WEIGHT (force) which is a vector and hence calculate the component of the weight (force) acting down the incline. GRAVITY, however, always acts toward the center of the earth, and hence vertically "downward". Draw the incline on a huge circle representing the Earth if you still find it hard to grapple with. By any chance are you doing M1 (UK math syllabus)?
No I am not doing M1..so I am not too sure about my resolving. So given the question above is my resolving that I have done correct..please help!
You should end up with [itex]R = mg\cos 30[/itex] but why you want to find [itex]R[/itex] I don't quite know as you are only really concerned with the components parallel to the inclined plane. You want to calculate the force of gravity acting parallel to the plane.
right, and isn't the frictional force the only component that is parallel to the inclined plane? therefore do we need to resolve it. Plus does mg sin 30 equal to the component of the weight (force) acting down the incline?
consider the forces acting along the incline.when you consider mg acting downward,u cannot additionally consider g.So,do the following-
Resolve mg along the incline which would be mgsin30.So,net force acting along the incline=mgsin30-F where F is frictional force opposing the movement.
Finally,net force=ma
i.e.,mgsin30-F=ma.
Deduce F.
Yes, you are right! Now all you have to do is substitute in the formula we have just defined and the values into:
[tex]F_{gravity} - F_{frictional} = ma[/tex]
Show the equation first, then put the numbers in a work through until you have an answer for the frictional force. Post your working and asnwer here.
Got it.I would end up getting mg sin 30-F=ma. Therby rougly i would end up getting about 330 N of friction...thanks guys
Yep, you got it.
