Can Two Identical Batteries Power Two Bulbs as Brightly as One?
  • Thread starter Thread starter nophun6
    Battery Circuit
Connecting two identical batteries to power two bulbs in series does not result in the same brightness as one bulb powered by one battery. In both scenarios, the current flowing through the circuit is 0.38 A. However, in the case of two bulbs in series, each bulb experiences a voltage drop of 1.5V, leading to identical brightness compared to a single bulb with one battery. The reasoning confirms that current remains constant throughout a series circuit, validating that both configurations yield the same current and brightness for each bulb.
  • Understanding of Ohm's Law
  • Basic knowledge of series circuits
  • Familiarity with voltage, current, and resistance concepts
  • Ability to perform simple electrical calculations
  • Study Ohm's Law and its applications in circuit analysis
  • Learn about series and parallel circuit configurations
  • Explore the concept of voltage drops across resistors in series
  • Investigate practical experiments with batteries and light bulbs to observe circuit behavior
Students in physics, electrical engineers, hobbyists experimenting with circuits, and anyone interested in understanding basic electrical principles.
nophun6
Hello.
Here is my question: Is it possible to connect 2 identical batteries to make 2 bulbs connected in series light just as brightly as one bulb connected to one battery?
Reasoning: let's say each battery has a voltage of 1.5V and that each light bulb is equal and has a resistance of 4 ohms.
Now in circuit 1, with two identical batteries and bulbs, the current flowing through the circuit would I = (1.5V+1.5V) / (4ohms+4ohms) = .38 A
Now in circuit 2, with one battery and bulb, the current flowing through the circuit would be I = (1.5V) / (4ohms) = .38A
We know that the amount of current flowing through a light bulb determines its brightness, and thus in circuit 2, .38 A is flowing through 2 bulbs, and in circuit 1 the same amount of current is flowing through only 1 light bulb, thus it is not possible,
Can someone tell me if this is right? Much appreciated.
Current is continuous through all parts of a series circuit. Consider two bulbs in series: if one bulb has 0.38 A flowing through it, the other must also.
Consider electrons in a wire to behave much like water in a pipe. If some volume of water is flowing through part of a pipe every second, the same volume must be flowing through every other part of the pipe every second.
In the case of (1 bulb, one battery), the bulb drops 1.5V and carries 0.38A of current. In the case of (2 bulbs, 2 batteries), each bulb drops 1.5V and carries 0.38A. Each of those two bulbs would be lit identically to the single bulb, single battery situation.
- Warren
I think it also depends on what the voltage drop across each bulb (resistor) is.
