After Ball Launch: How High Does It Reach?
  • Thread starter Thread starter sauri
    Ball Launch
The discussion focuses on calculating the height at which a ball, thrown at a speed of 15.0 m/s and an angle of 40.0° above the horizontal, strikes a wall located 10.0 m away. The vertical component of the initial velocity is determined using the formula v = v(initial) sin(angle), while the motion is influenced by the constant acceleration due to gravity. The key equations for solving the problem include the horizontal motion equation x = x_0 + v_{0x}t and the vertical motion equation y = y_0 + v_{0y}t - (1/2)gt². The time of flight before the ball hits the wall is essential for determining the height of impact.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Knowledge of trigonometric functions, specifically sine
  • Basic grasp of gravitational acceleration (9.81 m/s²)
  • Calculate the time of flight using the horizontal motion equation.
  • Determine the vertical position of the ball using the vertical motion equation.
  • Explore the impact of different launch angles on projectile height.
  • Investigate the effects of varying initial speeds on projectile motion outcomes.
Students studying physics, educators teaching projectile motion, and anyone interested in understanding the dynamics of thrown objects in a gravitational field.
sauri
A student throws a ball with a speed of 15.0 m.s-1 at an angle of 40.0° above the horizontal directly toward a wall as shown below. The wall is 10.0 m from the release point of the ball.
Now I did figure this out. The vertical component of velocity (initial) is v= v(inital) sin angle, and in the vertical direction the ball has the constant acceleration due to gravity. So v = v(initial) sin angle - gt should be true for any given time.
I can't figure out how far above the release point does the ball hit the wall?
Let's start by listing all the possible equations you can use. There are 5.
There's no acceleration in the x direction so:
[tex]x=x_0+v_{0x}t[/tex]
In the y direction:
[tex]y=y_0+v_{0y}t+(1/2)a_yt^2[/tex]
[tex]y=y_0+(1/2)(v_{0y}+v_y)t[tex] [tex]v_y=v_{0y}+a_yt[/tex]<br /> [tex]v_y^2=v_{0y}^2+2a_y(y-y_0)[/tex]<br /> <br /> So sketch your diagram. I'd recommend setting the origin where the ball is released and +x to the right, and +y upward.<br /> <br /> Which equation do you need to use to find how high the ball strikes the wall? What do you need to solve it?<br /> <br /> -Dan[/tex][/tex]
If you found how long is the ball in the air before it hits the wall, it can be used to answer your question. As you said the vertical position of the ball at anytime will be y = (v0 sin)t – ½ gt2. So if you find the time it will be a simple matter of substitution into the equation.
Hope this will help.
  • · Replies 38 ·
