Register to reply
Ball rolling down a ramp question again (different than traditional ones)
by libin
Tags: ball, ramp, rolling, traditional
Share this thread:
libin
#1
Mar3-06, 07:23 PM
P: 12
Hello everyone. I am new to the forum. And this is my first question.
Consider an experiment with a ball rolling down a ramp. We have to determine several factors effecting its average speed. Please CONTINUE READING BECAUSE THIS IS A DIFFERENT QUESTION THAN THE TRADITIONAL ONES. Now, the factor i was assigned to was "length of the ramp". Now, all factors (slope, angle of elevation, ball type, mass, density, height of ramp and everything else) are all controlled. My prediction was that the speed would increase as the length of the ramp increases. This is because that the acceleration down the ramp is constant. The longer the time, the higher the final speed. When i did the experiment however, i found weird answers. There was no certain pattern! I am really confused. I would like an answer or another explanation of the situation. There could be a mistake as I did the experiment in a hurry and i may have made a mistake.
Thanks in advance.
Phys.Org News Partner Science news on Phys.org
Flapping baby birds give clues to origin of flight
Prions can trigger 'stuck' wine fermentations, researchers find
Socially-assistive robots help kids with autism learn by providing personalized prompts
what
#2
Mar3-06, 07:59 PM
P: 91
First question, how did you change the "length of the ramp" if both height and angle of elevation were constant? Also how did you take in account friction?
In my opinion trying to answer these questions should give you some insight on why your results don't show the pattern you were looking for.
Doc Al
#3
Mar3-06, 08:06 PM
Mentor
Doc Al's Avatar
P: 41,460
Quote Quote by libin
You thinking sounds reasonable to me. Why don't you quantify it by figuring out exactly how average speed depends on distance? (For example: If you double the distance, what happens to the average speed?)
How did you vary the distance without changing anything else? How did you calculate the average speed? What did you measure?
As far as not being careful... too late to help you with that!
libin
#4
Mar4-06, 08:11 AM
P: 12
Ok. With the controlled factor part. In the experiment, the height was controlled by placing a book under the ramp. Now, the ramp formed is elevated at a certain angle. When i added another part to the ramp, the same book was placed.
For the average speed part. This is what i used. I recoreded down the time it took for the ball roll down the ramp. Then i measured the length of the ramp. Using the formula "S=D/T", i calculated the speed for each try. There are a total of 10 tries. So, i found the average of all my answers.
Yes, i admit i did not be careful. Because this is the first time i actually do an experiment. Before i just did only the quantitive part of physics. Could someone just predict what will happen? Thanks to "Doc AL" and "What" for your answers.
Hootenanny
#5
Mar4-06, 08:45 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,772
Instead of considering forces, try considering energy:
At the top of the ramp the ball will have a potential energy of [itex]mgh[/itex], where [itex]h[/itex] is the vertical height of the ramp.
Now, ignoring friction the loss in potential energy will be equal to the kinetic energy:
[tex]\frac{1}{2}mv^2 = mg\Delta h[/tex]
Rearranging and cancelling the masses we have:
[tex]v^2 = 2g\Delta h[/tex]
Using trig to find the ramp length in terms of h gives:
[tex]l\sin\theta = h[/tex]
where [itex]\theta[/itex] is the angle between the horizontal and the ramp.
Subsituting [itex]h[/itex] into the equation gives:
[tex]v^2 = 2g\left(h - l\sin\theta\right)[/tex]
[tex]v = \sqrt{2g\left(h - l\sin\theta\right)[/tex]
This should give you a model for you to predict what 'should' happen.
Hurkyl
#6
Mar4-06, 08:56 AM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,091
And be careful when computing the average -- you can't just take the beginning and ending velocities and take their average!
E.g. the classic paradox of average velocities is that going X miles at 45 miles per hour, and X miles at 55 miles per hour does not average out to 50 miles per hour!
I would think you would need an integral -- I've not yet been able to come up with an idea for a shortcut.
(P.S. if you're interested in the fastest ramp, see Tautochrone at Mathworld or Brachistochrone at wikipedia. They are two related problems, and these are the ones with pictures. )
Doc Al
#7
Mar4-06, 09:04 AM
Mentor
Doc Al's Avatar
P: 41,460
Quote Quote by Hurkyl
In this case you can, since the acceleration is constant.
libin used D/T to find the average speed. Also good.
Doc Al
#8
Mar4-06, 09:21 AM
Mentor
Doc Al's Avatar
P: 41,460
Sounds to me like you varied not just the length of the ramp, but the angle as well. If you keep the height the same, what would you expect to happen to the average speed?
Sounds to me like you kept the height the same but changed the length and angle of the ramp. Perhaps you thought you were changing only the length, and keeping everything else fixed--but not so. You kept changing the angle so that the height remained fixed. Now... what would you expect to see?
Hootenanny
#9
Mar4-06, 09:22 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,772
Sorry an error I just noticed in my last post, the equation should read:
[tex]v = \sqrt{2gl\sin\theta\right)[/tex]
Where [itex]l[/itex] is the distance which the ball has travelled down the ramp. Apologies.
Doc Al
#10
Mar4-06, 09:28 AM
Mentor
Doc Al's Avatar
P: 41,460
Unfortunately, it looks like libin kept conditions such that [itex]h = l \sin \theta[/itex] remained constant. I'll bet his results were just what one would expect, but not what he thought he was measuring.
libin
#11
Mar4-06, 01:21 PM
P: 12
Thanks to all of your guy's answers. But actually this is a presentation i have to give to my grade 10 science classmates. They do not understand anything about force or energy etc. I do understand the equations concerning energy and force, but i cannot use it according to my teacher. The aim is just to show how does the length effect the speed of the ball in the simplest manner. Could someone just sum up everything here and give me an accurate hypothesis.
And for Doc Al's questions. I kept the angle the same. This is done by just adding an extra length at the begginning of the ramp. As i said, a book was placed under the ramp. I didn't change that height which is the height of the book. Now, extending the ramp doesn't change the angle for sure. It's like extending one of the rays of an angle. Now, for the height. I am confused about that as well. Then in this case, if i extend the ramp, the height has to change. If so, how can i do such an experiment.
The sad thing is that i cannot use any of the equation you guys gave me. I just need a simple explanation. Something like "as the length increases, the speed increases."
Once again, thank you guys.
Doc Al
#12
Mar4-06, 03:47 PM
Mentor
Doc Al's Avatar
P: 41,460
Did I misinterpret what you described before? If you kept the angle fixed, then the height must change accordingly as the length is increased. (Did you change the height? Yes or no?) As you realize, some of the variables are mathematically linked: the height, length, and angle define a triangle. You can't change just one without affecting at least one other. You can only keep one of those three fixed at a time.
If you kept the angle fixed, while varying the length (and height) of the ramp, what did your results show?
That's certainly a reasonable statement. (Assuming you kept the angle fixed.) Since the ball accelerates down the ramp, the longer it rolls the faster it goes. Thus the average speed must increase as it rolls a longer distance.
libin
#13
Mar4-06, 06:05 PM
P: 12
Ok. The angle is fixed, but the height varied. That's what i have done. Maybe I ignore that. Now, if this is the case, is my hypothesis correct?
Hootenanny
#14
Mar5-06, 04:46 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,772
If you varied the height as well as the length, then your hypothesis is correct.
Doc Al
#15
Mar5-06, 07:05 AM
Mentor
Doc Al's Avatar
P: 41,460
Regardless of your hypothesis, what did your measurements show?
Hootenanny
#16
Mar5-06, 07:24 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,772
Also, could you give some quantative values?
libin
#17
Mar5-06, 08:09 AM
P: 12
OK. The reason why I did not want to show quantitative values is because they does not make sense and I think my mate who was doing the experiment with me made a huge mistake. However, I was absent doing the experiment so I can't really change what is already done.
Anyhow, there was no trend. The speed increased, then decreased, but then increased again. That's why it's so weird.
Thanks
libin
#18
Mar5-06, 08:18 AM
P: 12
Another question. The formula that you give doesn't seem to be correct. When I substituted my data into the formula, I did not find a measurement for Sin of the angle of elevation.
Register to reply
Related Discussions
Rolling Ball off a ramp Introductory Physics Homework 3
Ball rolling down a ramp Introductory Physics Homework 10
Ball and ramp question Introductory Physics Homework 2
Rolling ball down ramp Introductory Physics Homework 2
Ball rolling down ramp off a table Introductory Physics Homework 2
