Finding Gradient of Temperature at (x,y,z)
  • Thread starter Thread starter UrbanXrisis
    Gradient
The discussion revolves around finding the gradient of temperature in a gaseous nebula, where temperature is inversely proportional to the distance from the origin. The original poster presents an equation for temperature based on their interpretation of the problem.
  • The original poster attempts to derive the gradient of temperature using their formulation but questions their approach. Some participants clarify the relationship between temperature and distance, suggesting a constant factor and questioning the original poster's assumptions about distance.
Participants are actively engaging with the original poster's reasoning, providing clarifications and prompting further exploration of the problem. There is a productive exchange regarding the correct formulation of the temperature equation and the constant involved.
There is an emphasis on ensuring the correct interpretation of the problem's conditions, particularly regarding the relationship between temperature and distance. The original poster's initial assumptions are being scrutinized, and the need for a constant in the temperature equation is highlighted.
UrbanXrisis
Suppose distances are measured in lightyears and that the temperature T of a gaseous nebula is inversely proportional to the distance from a fixed point, which is the origin. The temperature 1 lightyear from the origin is 100 degrees celsius. Find the gradient of T at (x,y,z).
here's what I have:
[tex]d=\sqrt{x^2+y^2+z^2}=1[/tex]
[tex]d=x^2+y^2+z^2=1[/tex]
[tex]T=\frac{1}{x^2+y^2+z^2}[/tex]
so the gradient is:
[tex]T_x=-\frac{2x}{(x^2+y^2+z^2)^2}[/tex]
[tex]T_y=-\frac{2y}{(x^2+y^2+z^2)^2}[/tex]
[tex]T_z=-\frac{2z}{(x^2+y^2+z^2)^2}[/tex]
but this is not right, i where did I go wrong?
First of all, read your info properly!
You are told that T(x,y,z) is inversely proportional to the distance from the origin. That means there exist a constant K, so that we have:
[tex]T(x,y,z)=\frac{K}{\sqrt{x^{2}+y^{2}+z^{2}}}[/tex]
Furthermore, you have the condition:
[tex]T(x,y,z)=100, \sqrt{x^{2}+y^{2}+z^{2}}=1[/tex]
Can you determine K from this?
The first equation you have for distance is correct but I don't see why you are setting it to 1. Then you squared it but didn't write d^2...
The distance from the origin is sqrt(x^2 + y^2 + z^2). T is inversely proportional to that distance so T(x, y, z) = k/sqrt(x^2 + y^2 + z^2) where k is some constant. You know that T(x, y, z) = 100 when sqrt(x^2 + y^2 + z^2) = 1, so what is k? Then you can find the gradient.
Do you need a confirmation on that question?
nope, i got it! thanks!
