Uncovering the Practical Applications of Differential Equations
  • Context: Undergrad
  • Thread starter Thread starter PrudensOptimus
    Application Diff eq
The discussion revolves around the practical applications and true uses of differential equations, exploring their historical context, theoretical implications, and real-world applications. Participants engage in both conceptual and technical reasoning regarding the nature and significance of differential equations in various fields.
  • Some participants suggest that the origin of differential equations was to explain the motion of bodies, emphasizing the role of initial conditions in predicting future states.
  • Others argue that framing the use of differential equations solely in terms of predicting the future is misleading, proposing instead that they serve as a means for universities to monetize knowledge.
  • A participant presents a first-degree differential equation and questions how the concept of "future" is represented within it, indicating a belief that the derivative represents future values while the function itself represents initial conditions.
  • Another participant elaborates on the integration process related to a specific differential equation, connecting the integration factor to the concept of determinism and the relationship between present and future states.
  • One participant provides examples of practical applications of differential equations, such as radioactive decay and Newton's second law, highlighting their utility in formulating problems and the necessity of solving them for various initial conditions.
Participants express differing views on the true use of differential equations, with some emphasizing their historical and theoretical significance while others focus on practical applications and the economic aspects of education. The discussion remains unresolved with multiple competing perspectives present.
Participants reference specific mathematical formulations and integration techniques without reaching a consensus on their implications or interpretations. The discussion includes assumptions about the relationship between initial conditions and future predictions that are not universally accepted.
PrudensOptimus
What is the true use of Differential Equations?
This question is very vague. The origin of differential equations, was to explain the motion of bodies. If you know the initial conditions, then you also know the future. This was the central idea behind the pioneering work. But to say that predicting the future is the true use of differential equations, is misleading. The true use of differential equations, is this:
Universities can sell knowledge to people, and so make a whole lot of money. That is the true 'use' of differential equations. :)
OK, I saw a First degree diff eq:
y' + p(x)y = q(x)
as a general solution to y = [tex]\frac{\int{}u(x)q(x)dx + C}{u(x)}[/tex]
u = exp(∫p(x)dx)
can someone show me what is the "future" in that equation? I thought y' is more of future, and y is initial??
I am going to just sort of think about the following equation 'aloud' as it were.
y' + p(x)y = q(x)
r(x)dy/dx + r(x)p(x)y = r(x)q(x)
d/dx[ y r(x)] = r(x)dy/dx + ydr/dx
Thus, we need dr/dx = r(x)p(x)
From which it will follow that if we multiply both sides of the original equation by r(x) we have the following sequence of work:
r(x)[y' + p(x)y] = r(x)q(x)
r(x)y' + r(x)p(x)y = r(x)q(x)
d/dx[ y r(x)] = r(x)q(x)
Which will lead us to
d[ y r(x)] = r(x)q(x)dx
Then we can integrate both sides of the above equation to get:
y r(x)= INtegral of [ r(x)q(x)dx ]
And finally we can solve for y(x)
hence the integration factor is found from the following formula:
dr/dx = r(x)p(x)
And all we have to do is solve for r(x), and this is trivial.
dr/r = p(x)dx
From which it follows that
ln (r(x)) = Integral of p(x)
Thus, r(x) equals e^ integral of (p(x)dx)
Or using Latex:
[tex]ln [r(x)] = \int{}p(x)dx[/tex]
As to how one is to see the future related to the present in this whole thread, all I can say is then when you integrate something over time, you always see how differential equations is intimately connected to determinism.
Amazing. Give me sometime, I shall cogitate on this matter.
What is the use of differential equations?
It is often easy or useful to formulate a problem in terms of a differential equation. Some examples:Radioactive decay--the counting rate in a system of radioactive atoms is proportional to the number of atoms present. The differential equation is dn/dt=-g n, where the derivative is the number of atoms that decay per unit time and g is related to the lifetime. This was trivial to set up, and it has a simple exponential solution. Or consider Newton's famous equation F=ma. Here a is really the second derivative with respect to time:F=m d^2x/dt^2 (for the simple case of one-dimensional motion. In this case two initial conditions are neede, since the equation is of second order:initial position and initial velocity. The problem is then trying to solve the DE. And that keeps us employed!
  • · Replies 17 ·
