Calculating Spring Compression from a Collision with No Friction
  • Thread starter Thread starter atomant
    Collision Force
The problem involves a mass sliding down a height and colliding with a spring, focusing on calculating the compression of the spring. The subject area includes energy conservation principles in mechanics.
  • Participants discuss the conversion of potential energy to kinetic energy and how this relates to the compression of the spring. Questions arise about the lack of numerical values and how to express the compression in terms of variables.
Some participants have provided guidance on using energy conservation principles, while others are clarifying their understanding of kinetic and potential energy terms. Multiple interpretations of the energy transfer process are being explored, and there is no explicit consensus on the final expression for compression.
Participants note the absence of specific numerical values in the problem and discuss how this affects their ability to arrive at a definitive answer.
atomant
A body of mass m slides without friction from rest at height H to a lower height h, where it encounters a horizontal spring with strength k. by how much does it compress?
To solve this i was wondering if we needed to take into account the changes in energy of the body. i.e 1/2 mv^2=mgh and if the force of the collision can be substitiuted into mg=kx?
exactly right, think of the problem setup as two sub cases. since there are no dissaptive forces in the problem then all the potential energy will be converted to kinetic energy, if we take our zero for the potential at the level of the spring. so this is the first part. now treat this as the initial condition for the second part, so the particle now has the total kinetic energy and use the energy theorem again to assume that the total kinetic goes into potential for compressing the spring. hope this helps, sincerely, x
so the total potential energy mgh is=kx. but I don't understand that, as the question does not give any values how do I answer the question?. If I was to solve for x the equation would read as x=mgh/k. So o I just state that the compression is equall to the mgh/k or is there another method for answering this. Thanks!
you're on the right path for the trip down, assuming the particle starts at rest then we have
[tex]T_{f}^{part1} = U_{i}^{part1}\Rightarrow T_{f}^{part1} = mg (H-h)[/tex]
now
[tex]T_{f}^{part1}= T_{i}^{part2} = U_{f}^{part2}-U_{i}^{part2} \Rightarrow mg(H-h)=\frac{k}{2} x^{2} - m g h[/tex]
and solve for [tex]x[/tex]
Note that you may of course set the potential of at h to zero and initially and you get the same answer.
[tex]mgH=\frac{k}{2} x^{2}[/tex]
either way.
I see, it's clear except for the T_{f} and U_{i} part. That is suppose to represent the final kinetic (T_{f}) and initial potential (U_{i}) right?
So just to be clear, T(f) is the final kinetic energy and U(i) is the initial potential energy. Is that correct?
Yeah, the gravitational potential energy is completely converted into mechanical kinetic energy for the first part of problem so
[tex]T=KE=\frac{m}{2}v^{2}=U=mgH-h\Rightarrow T_{f}=U_{i} \Rightarrow T_{f} =m g H[/tex] where we take the height at [tex]h[/tex] the zero for the potential energy. Now for the second part we assume the particle hitting the spring has the initial kinetic energy from the final kinetic energy of the first part of problem -- note, it is this kinetic energy that will go into compressing the spring, which we assume all the kinetic energy is again converted into potential, but this time the potential is in the compression of the spring. So
[tex]U_{spring} = T_{i}^{part2}=T_{f}^{part1}=U_{grav}^{part1}\Rightarrow<br /> \frac{k}{2}x^{2} = m g H\Rightarrow x=\sqrt{\frac{2mgH}{k}}[/tex]
  • · Replies 58 ·
  • · Replies 22 ·
  • · Replies 20 ·
