The discussion revolves around determining the number of elements in the set {x^(13n) : n is a positive integer} within the context of group theory, specifically focusing on cyclic groups and their properties. Participants explore the implications of the order of an element in a cyclic group of order 15 and the conditions under which certain elements can be equal.
- Technical explanation
- Conceptual clarification
- Debate/contested
- One participant claims that the number of elements in the set {x^(13n) : n is a positive integer} is 3, based on the properties of a cyclic group of order 15.
- Another participant explains that if the set {x^3, x^5, x^9} has exactly two elements, then one of the elements must be equal to another, leading to the assumption that |x|=3.
- It is noted that if |x|=3, then |x^(13)| can be calculated using the formula |x^k|=n/gcd(n,k), resulting in |x^(13)|=3.
- A participant expresses confusion about the assumption of |x|=3 and requests clarification on the formula used and an example of a set that meets the discussed conditions.
- Further clarification is provided regarding the theorem that relates the order of an element to the divisibility of indices, emphasizing that if |x|=3, then x^3 must equal x^9.
Participants express varying levels of understanding regarding the assumptions made about the order of the element x. While some points are clarified, there remains uncertainty about the initial assumption of |x|=3 and the application of the relevant theorems.
There are limitations in the discussion regarding the assumptions made about the order of elements in cyclic groups and the specific conditions under which certain elements can be equal. The discussion does not resolve these uncertainties.
