Can Anyone Help with These RSA Encryption Questions?
  • Context: Graduate
  • Thread starter Thread starter buzzmath
    Cryptography
This discussion focuses on two RSA encryption problems. The first involves decrypting a ciphertext message using the RSA key (5, 2881) and requires calculating C^1109 mod 2881 for the ciphertext blocks. The second problem addresses the recovery of a plaintext message P encrypted with an exponent of 3 by three different users with distinct moduli, leading to the congruences c_i ≡ P^3 (mod n_i). The solution for the first problem involves using repeated squaring and modular reduction, while the second problem hints at the necessity of recovering P^3 before proceeding.
  • RSA encryption fundamentals
  • Modular arithmetic techniques
  • Understanding of Euler's totient function
  • Repeated squaring method for exponentiation
  • Learn how to implement repeated squaring for modular exponentiation
  • Study the properties of Euler's totient function in RSA
  • Explore methods for recovering plaintext from multiple ciphertexts in RSA
  • Investigate the implications of using small encryption exponents in RSA
Cryptography students, security researchers, and software developers working with RSA encryption and decryption techniques.
buzzmath
I'm trying to figure out these two questions
1. I have a ciphertext message produced by RSA encryption with key (e,n)=(5,2881) and I'm trying to find the plain text message of
0504 1874 0347 0515 2088 2356 0736 0468
I found the euler-phi function to be 42*66=2772 and found the modular inverse to be 1109 but I'm having trouble finding C^1109(mod2881) for each block of four. can anyone help with this?
2. I'm trying to show that if the encryption exponent 3 is used for the RSA cryptosystem by 3 different people with different moduli, and a plaintext message P encrypted usin each of their keys can be recovered from the resulting 3 ciphertext messages.
I've set it up to the congruences c_i congruent to P^3(mod n_i), i = 1,2,3 but I'm not really sure where to go from here. can anyone help?
thanks
buzzmath said:
i'm having trouble finding C^1109(mod2881) for each block of four. can anyone help with this?
Use repeated squaring and reduce mod 2881 at each stage. That is find C^2 mod 2881, C^4 mod 2881, C^8 mod 2881, etc. then multiple the appropriate ones to get C^1109, reducing mod 2881 as necessary to keep the numbers small.
small hint- P will be less than each n_i. Do you have any way of first recovering P^3?
